Im trying to create a somewhat autonomous car. I bought a smaller RC car from Radioshack, ripped out all the internal circuit board components, and am going to replace them with my arduino. I also bought this motor shied from Radioshack ->
http://www.ebay.com/itm/like/400778673527?lpid=82&chn=psMy RC car came with two motors built into it. One of them spins the back tires, while the other is used to steer the front tires. I ripped out the front motor for steering and replaced with small servo that i have. My Motor shield uses pins 8 - 13, and i have ultrasonic sensor hooked up to pins 6 and 7, with my servo connected to pin 5. I have no programming errors(that i know of). But after i compile my code, and upload it to the Arduino, my servo motor will tick, like its trying to do something, and my DC motor doesn't move at all.
When i comment out the code the set the servo to pin 5, the DC motor runs just fine. But when I have servo active, the DC motor doesn't run at all. If i unplug the Servo sensor pin(5), the dc motor still doesn't run at all.
So it seems when I do any kind of initialization of my Servo, the dc motors doesn't run.
here is an example of the first part of my code.
#include <MotorDriver.h>
#include <Servo.h>
#define servoPin 5
#define trigPin 6
#define echoPin 7
long duration, distance;
Servo myservo;
int pos = 0; //used to track where the servo is
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
//motor code for my Arduino Shield I got from Radio Shack
motordriver.init();
motordriver.setSpeed(200, MOTORB); //probably dont need this since i only have 1 motor connected.
motordriver.setSpeed(200, MOTORA); //setting up only one motor here, because the other set isn't used at all.
//servo motor used to steer
myservo.attach(servoPin); // attaches the servo on servoPin to the servo object
myservo.write(15); //sets the position of the servo so it always aligns the wheels straight
the rest of the code is just what to do with the information gotten from the ping sensor, probably not important, so i wont clutter up my post with it.
So my question is, does anyone have any ideas why the DC motor connected to the shield doesnt work when I initialize my servo?
