Topic: Balancing Robot PID  (Read 1 time) previous topic - next topic
HeroAwake13
Hey guys, any of you have experience in making balancing robots? I am having a bit of trouble with the integral part. The integral keep on increasing and it only reduce when the robot tilts to the other side. How is the code suppose to be?
yoko911
Hello Compadre,
What formula are u using?
Have you added an anti-windup part? this sounds as a saturation of the integral part.
Regards.
MarkT
In general if you are responding to a step-change (rapid increase in error) or the output
is saturating, you should just zero the stored integral value, its not doing anything useful
until the system is approaching the target smoothly in the linear response realm.
A good test for a servomotor PID is to just have it hold still and you work against it by
hand, feeling for its behaviour, especially when you release the pressure.
Astrocode317
Astrocode317
would you have to put in a balancing circuit of some sort?
Sacha22
"Windup" is the behavior of an integral controler that keeps acting in the same direction even after the error sign has changed. It's due to the integrator's nature: if it's stored value is positive and the error is negative then the stored value will decrease slowly as the new errors is integrated over time.
There are several technics to reduce the windup effect. A simple one is, like MarkT suggested, to reset the integrator value when you're responding to a fast change in the setpoint value. When you're getting close to the setpoint, you then enable again the integrator.
sesmd
From SESMD... addendum to prior post.
absolute value of  accelerometer result - control value         (for each axis) used to set drive
current to each motor.   Values pos or neg used to set polarity of current to appropriate
motor.
Stan   (sesmd)
sesmd
Sorry about all the addendums, but another point came to mind, which
would make things easier.....   it would be extremely useful to keep the
Center of Gravity of your balancing robot as LOW as possible.  If it
(the COG)  migrates upwards, you may reach a point where escalating
oscillations may develope in one or both axes, resulting in loss of control,
and a 'crash'.
sesmd
MarkT
No, C.o.G. wants to be as _high_ as possible to make the balancing easier.  Try balancing
sticks of different lengths and you'll soon see shorter sticks fall over much faster.
Oscillations in a PID system are principally controlled by the D term, set the I term to zero
in the first instance and get the balance (no pun intended) between P and D terms roughly
right first).
