Topic: USBasp non updateable board fix (Read 724 times) previous topic - next topic
CyrusMainTea
Some pictures of the jumper mod I made to enable firmware updates on non updateable boards. Some baught off ebay for example.
Simple design. Connect the header reset pin to the qfp chips correct reset pin via (green blue brown gold) resistor. Then put the two jumper leads 1. At the qfp chip reset pin and 2. At the resistor underneath The board. mines called R1.
Simply enable the jumper. Flash via arduinoisp.
