Topic: external power supply - maximum input current (Read 37725 times) previous topic - next topic
pedro
I have an external power supply DC 9V 600mA. It is ok to use it on Arduino? The recommended maximum input voltage is 12V, what is the recommend maximum input current?
mem
#1
Sep 08, 2009, 12:13 pm Last Edit: Sep 08, 2009, 12:13 pm by mem Reason: 1
Yes, that should be a good match for your Arduino.
There is no maximum current rating for the power supply connected to Arduino, the Arduino will draw as much current as it needs (and the voltage regulator can cope with). But you should be good to go with that 9v 600ma supply.
pedro
thanks mem!
ou, em português, obrigado (i put this post in the wrong forum .-)
orangeroo
Can i use a 7.4V 800mAh power supply with the Arduino Mega?
orangeroo
Ok, thanks :) Was worried about the current..
jaysettle
Would an extreme 12V, 4.5A power source be ok or would the onboard arduino voltage regulator fry?
netogdo
The voltage regulator probably will explode if your circuit drains 4.5 A.
But if the source is 12V/4.5A, doesn't mean that this current will flow in the circuit, it's only the maximun current that the source supports.
