Topic: Wheres the Analog in or (A0) pin (Read 26470 times) previous topic - next topic
Legoman39
Jan 24, 2015, 04:21 am Last Edit: Jan 24, 2015, 04:22 am by Legoman39
Wheres the Analog in or (A0) pin on the arduino esplora??? :smiley-small:  :smiley-small:  :smiley-small:
AWOL
#1
Jan 26, 2015, 01:50 pm Last Edit: Jan 27, 2015, 08:49 am by AWOL
I think it's used as an output to address the analogue mux.
Legoman39
Thanks but all ready using the Uno.
AWOL
Legoman39
I'm just starting to use the Uno, if that makes more sense
PCWorxLA
Not really, considering that you are posting in the Arduino Esplora forum, which is a very specialized Arduino board (and quite different from an Arduino Uno)...  :smiley-confuse:
Ralf
Legoman39
what i'm saying is when I posted it I was using arduino esplora then I started using the uno because I didn't think there was a A0 pin on the esplora
runaway_pancake
You've switched over to the Uno, but in case anyone else is reading along, the Esplora has two input pins available as described at the following link
http://21stdigitalhome.blogspot.com/2013/03/reading-arduino-esplora-tinkerkit-inputs.html
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
