Topic: SdFat Linking Issues (Read 6256 times) previous topic - next topic
otrcomm
Hello All,
I am fairly new to programming the Uno and need help with getting SdFat to link. I am using IDE 1.0.6 on a Debian Wheezy box. I followed the instructions at http://arduino.cc/en/Guide/Libraries  I downloaded SdFat.zip and installed it through 1.0.6->Sketch->Import Library... SdFat was installed in my sketchbook/libraries/SdFat directory and the SdFat library appears in the Sketch->Import Library menu.
I see ~/sketchbook/libraries/SdFat when I echo $LD_LIBRARY_PATH
However, I can not get any of my sketches to link to the SdFar libraries. I can link to the SD libraries fine.
Any ideas?
Thanks,
Murrah Boswell
nickgammon
What do you mean? What message do you get? What sketch? What error message?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
otrcomm
#2
Jan 21, 2015, 10:30 pm Last Edit: Jan 21, 2015, 10:39 pm by otrcomm
Thank you for your response, sorry to take so long to get back to you response.
Listing of example sketch SdFatRewrite:
 * Rewrite Example
 * This sketch shows how to rewrite part of a line in the middle
 * of the file created by the SdFatAppend.pde example.
 * Check around line 30 of pass 50 of APPEND.TXT after running this sketch.
#include <SdFat.h>
#include <SdFatUtil.h> // use functions to print strings from flash memory
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char *str)
  PgmPrint("error: ");
  SerialPrintln_P(str);
  if (card.errorCode()) {
    PgmPrint("SD error: ");
    Serial.print(card.errorCode(), HEX);
    Serial.print(',');
    Serial.println(card.errorData(), HEX);
  while(1);
void setup(void)
  PgmPrintln("Type any character to start");
  while (!Serial.available());
  // initialize the SD card
  if (!card.init()) error("card.init");
  // initialize a FAT volume
  if (!volume.init(card)) error("volume.init");
  // open the root directory
  if (!root.openRoot(volume)) error("openRoot");
  char name[] = "APPEND.TXT";
  // open for read and write
  if (!file.open(root, name, O_RDWR)) {
    PgmPrint("Can't open ");
    Serial.println(name);
    PgmPrintln("Run the append example to create the file.");
    error("file.open");
  // seek to middle of file
  if (!file.seekSet(file.fileSize()/2)) error("file.seekSet");
  // find end of line
  int16_t c;
  while ((c = file.read()) > 0 && c != '\n');
  if (c < 0) error("file.read");
  // clear write error flag
  file.writeError = false;
  // rewrite the begining of the line at the current position
  file.write("**rewrite**");
  if (file.writeError) error("file.write");
  if (!file.close()) error("file.close");
  Serial.print(name);
  PgmPrintln(" rewrite done.");
void loop(void) {}
errors:
Arduino: 1.0.6 (Linux), Board: "Arduino Mega 2560 or Mega ADK"
/home/otrcomm/downloads/arduino-ide/arduino-1.0.6/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -I/home/otrcomm/downloads/arduino-ide/arduino-1.0.6/hardware/arduino/cores/arduino -I/home/otrcomm/downloads/arduino-ide/arduino-1.0.6/hardware/arduino/variants/mega -I/home/otrcomm/sketchbook/libraries/SdFat /tmp/build6496159611916882408.tmp/SdFatRewrite.cpp -o /tmp/build6496159611916882408.tmp/SdFatRewrite.cpp.o
In file included from /home/otrcomm/sketchbook/libraries/SdFat/SdFat.h:30,
                 from SdFatRewrite.pde:9:
/home/otrcomm/sketchbook/libraries/SdFat/Sd2Card.h:39:22: warning: extra tokens at end of #ifdef directive
In file included from SdFatRewrite.pde:10:
/home/otrcomm/sketchbook/libraries/SdFat/SdFatUtil.h:27:22: warning: WProgram.h: No such file or directory
In file included from SdFatRewrite.pde:9:
/home/otrcomm/sketchbook/libraries/SdFat/SdFat.h:294: error: conflicting return type specified for 'virtual void SdFile::write(uint8_t)'
/home/otrcomm/downloads/arduino-ide/arduino-1.0.6/hardware/arduino/cores/arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
/home/otrcomm/sketchbook/libraries/SdFat/SdFatUtil.h: In function 'void SerialPrint_P(const prog_char*)':
/home/otrcomm/sketchbook/libraries/SdFat/SdFatUtil.h:60: error: 'Serial' was not declared in this scope
/home/otrcomm/sketchbook/libraries/SdFat/SdFatUtil.h: In function 'void SerialPrintln_P(const prog_char*)':
/home/otrcomm/sketchbook/libraries/SdFat/SdFatUtil.h:71: error: 'Serial' was not declared in this scope
SdFatRewrite.pde: In function 'void error_P(const char*)':
SdFatRewrite.pde:21: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:24: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde: In function 'void setup()':
SdFatRewrite.pde:36: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:40: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:43: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:46: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:51: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:53: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:54: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:57: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:61: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:66: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:67: warning: only initialized variables can be placed into program memory area
SdFatRewrite.pde:69: warning: only initialized variables can be placed into program memory area
/home/otrcomm/sketchbook/libraries/SdFat/SdFatUtil.h: At global scope:
/home/otrcomm/sketchbook/libraries/SdFat/SdFatUtil.h:37: warning: 'int FreeRam()' defined but not used
I can not compile any of the examples provided the SdFat library.
Thanks in advance for your help!
fat16lib
#3
Jan 21, 2015, 11:04 pm Last Edit: Jan 21, 2015, 11:06 pm by fat16lib
What version of SdFat are you using?
Quote
This is from a really old library that can not be used with Arduino 1.0 or newer
Try this version of SdFat.
otrcomm
Hello, thanks for your response.
Using the version of SdFat that you provided the link to at GitHub and running the provided bench example sketch:
 * This sketch is a simple binary write/read benchmark.
#include <SdFat.h>
// SD chip select pin
const uint8_t chipSelect = SS;
// Size of read/write.
const size_t BUF_SIZE = 512;
// File size in MB where MB = 1,000,000 bytes.
const uint32_t FILE_SIZE_MB = 5;
// Write pass count.
const uint8_t WRITE_COUNT = 10;
// Read pass count.
const uint8_t READ_COUNT = 5;
// End of configuration constants.
// File size in bytes.
const uint32_t FILE_SIZE = 1000000UL*FILE_SIZE_MB;
uint8_t buf[BUF_SIZE];
// file system
SdFat sd;
// test file
SdFile file;
// Serial output stream
ArduinoOutStream cout(Serial);
#define error(s) sd.errorHalt_P(PSTR(s))
void cidDmp() {
  cid_t cid;
  if (!sd.card()->readCID(&cid)) {
    error("readCID failed");
  cout << pstr("\nManufacturer ID: ");
  cout << hex << int(cid.mid) << dec << endl;
  cout << pstr("OEM ID: ") << cid.oid[0] << cid.oid[1] << endl;
  cout << pstr("Product: ");
  for (uint8_t i = 0; i < 5; i++) {
    cout << cid.pnm;
  cout << pstr("\nVersion: ");
  cout << int(cid.prv_n) << '.' << int(cid.prv_m) << endl;
  cout << pstr("Serial number: ") << hex << cid.psn << dec << endl;
  cout << pstr("Manufacturing date: ");
  cout << int(cid.mdt_month) << '/';
  cout << (2000 + cid.mdt_year_low + 10 * cid.mdt_year_high) << endl;
  cout << endl;
  while (!Serial){}  // wait for Leonardo
  cout << pstr("\nUse a freshly formatted SD for best performance.\n");
  // use uppercase in hex and use 0X base prefix
  cout << uppercase << showbase << endl;
  float s;
  uint32_t t;
  uint32_t maxLatency;
  uint32_t minLatency;
  uint32_t totalLatency;
  // discard any input
  while (Serial.read() >= 0) {}
  // pstr stores strings in flash to save RAM
  cout << pstr("Type any character to start\n");
  while (Serial.read() <= 0) {}
  delay(400);  // catch Due reset problem
  cout << pstr("Free RAM: ") << FreeRam() << endl;
  // initialize the SD card at SPI_FULL_SPEED for best performance.
  // try SPI_HALF_SPEED if bus errors occur.
  if (!sd.begin(chipSelect, SPI_FULL_SPEED)) sd.initErrorHalt();
  cout << pstr("Type is FAT") << int(sd.vol()->fatType()) << endl;
  cout << pstr("Card size: ") << sd.card()->cardSize()*512E-9;
  cout << pstr(" GB (GB = 1E9 bytes)") << endl;
  cidDmp();
  // open or create file - truncate existing file.
  if (!file.open("BENCH.DAT", O_CREAT | O_TRUNC | O_RDWR)) {
    error("open failed");
  // fill buf with known data
  for (uint16_t i = 0; i < (BUF_SIZE-2); i++) {
    buf = 'A' + (i % 26);
  buf[BUF_SIZE-2] = '\r';
  buf[BUF_SIZE-1] = '\n';
  cout << pstr("File size ") << FILE_SIZE_MB << pstr(" MB\n");
  cout << pstr("Buffer size ") << BUF_SIZE << pstr(" bytes\n");
  cout << pstr("Starting write test, please wait.") << endl << endl;
  // do write test
  uint32_t n = FILE_SIZE/sizeof(buf);
  cout <<pstr("write speed and latency") << endl;
  cout << pstr("speed,max,min,avg") << endl;
  cout << pstr("KB/Sec,usec,usec,usec") << endl;
  for (uint8_t nTest = 0; nTest < WRITE_COUNT; nTest++) {
    file.truncate(0);
    maxLatency = 0;
    minLatency = 9999999;
    totalLatency = 0;
    t = millis();
    for (uint32_t i = 0; i < n; i++) {
      uint32_t m = micros();
      if (file.write(buf, sizeof(buf)) != sizeof(buf)) {
        error("write failed");
      m = micros() - m;
      if (maxLatency < m) maxLatency = m;
      if (minLatency > m) minLatency = m;
      totalLatency += m;
    file.sync();
    t = millis() - t;
    s = file.fileSize();
    cout << s/t <<',' << maxLatency << ',' << minLatency;
    cout << ',' << totalLatency/n << endl;
  cout << endl << pstr("Starting read test, please wait.") << endl;
  cout << endl <<pstr("read speed and latency") << endl;
  // do read test
  for (uint8_t nTest = 0; nTest < READ_COUNT; nTest++) {
    file.rewind();
    maxLatency = 0;
    totalLatency = 0;
    t = millis();
      buf[BUF_SIZE-1] = 0;
      if (file.read(buf, sizeof(buf)) != sizeof(buf)) {
        error("read failed");
      m = micros() - m;
      totalLatency += m;
      if (buf[BUF_SIZE-1] != '\n') {
        error("data check");
    t = millis() - t;
  cout << endl << pstr("Done") << endl;
  file.close();
I get errors:
  enabled in File > Preferences.
bench:30: error: 'SdFat' does not name a type
bench:33: error: 'SdFile' does not name a type
bench:36: error: 'ArduinoOutStream' does not name a type
bench.ino: In function 'void cidDmp()':
bench:42: error: 'cid_t' was not declared in this scope
bench:42: error: expected `;' before 'cid'
bench:43: error: 'sd' was not declared in this scope
bench:43: error: 'cid' was not declared in this scope
bench:46: error: 'cout' was not declared in this scope
bench:46: error: 'pstr' was not declared in this scope
bench:47: error: 'hex' was not declared in this scope
bench:47: error: 'cid' was not declared in this scope
bench:47: error: 'dec' was not declared in this scope
bench:47: error: 'endl' was not declared in this scope
bench.ino: In function 'void setup()':
bench:65: error: 'cout' was not declared in this scope
bench:65: error: 'pstr' was not declared in this scope
bench:68: error: 'uppercase' was not declared in this scope
bench:68: error: 'showbase' was not declared in this scope
bench:68: error: 'endl' was not declared in this scope
bench.ino: In function 'void loop()':
bench:82: error: 'cout' was not declared in this scope
bench:82: error: 'pstr' was not declared in this scope
bench:86: error: 'FreeRam' was not declared in this scope
bench:86: error: 'endl' was not declared in this scope
bench:90: error: 'sd' was not declared in this scope
bench:90: error: 'SPI_FULL_SPEED' was not declared in this scope
bench:92: error: 'sd' was not declared in this scope
bench:99: error: 'file' was not declared in this scope
bench:99: error: 'O_CREAT' was not declared in this scope
bench:99: error: 'O_TRUNC' was not declared in this scope
bench:99: error: 'O_RDWR' was not declared in this scope
bench:120: error: 'file' was not declared in this scope
bench:148: error: 'file' was not declared in this scope
bench:172: error: 'file' was not declared in this scope
Thank you in advance for your help,
Murrah Boswell
fat16lib
The library is not installed in the correct place.  You must manually install the SdFat folder in your libraries folder.
See the Manual installation section here.
otrcomm
I installed the SdFat library automatically using the 1.0.6 IDE and it got installed in my .../sketchbook/libraries directory. Then, at your suggestion, I removed it from my sketchbook/libraries folder and reinstalled it manually in my ../arduino-1.0.6/ibraries directory and got these errors trying to compile bench:
fat16lib
#7
Jan 22, 2015, 04:38 pm Last Edit: Jan 22, 2015, 04:56 pm by fat16lib
Please read this Arduino page again and follow it!  I said manual installation.
You must place the SdFat folder, in the sketchbook libraries folder.  the path to SdFat.h must be
otrcomm
Hello fat16lib,
Thank you for your patience. Now I understand. I did copy the SdFat directory with SdFat.h into my sketchbook/libraries and as you said, that was the solution. I can now link to the SdFat libraries.
Thank you very much,
Murrah Boswell
lilp
hello,
have same error....
I try to use this project.
The arduino 1.5.8 install path on my windows 8 x64 is: E:\Downloads\Arduino\arduino1.5.8_homeduino
The path to SdFat.h library is C:\Users\Packy\Documents\Arduino\libraries\SdFat\SdFat.h
gives:
Quote
FunkcontroloverNet.ino:13:19: fatal error: SdFat.h: No such file or directory
compilation terminated.
So i moved the SdFat.h library to E:\Downloads\Arduino\arduino1.5.8_homeduino\sketchbook\libraries\SdFat\SdFat.h
gives:
Quote
FunkcontroloverNet.ino:19:1: error: 'Sdvol' does not name a type
FunkcontroloverNet.ino: In function 'void setup()':
FunkcontroloverNet.ino:63:3: error: 'vol' was not declared in this scope
