Topic: Euclidean Sequencer Tap Tempo (Read 585 times) previous topic - next topic
Giò LFZ
Hi guys
sorry for cross posting
I've read some post on how to build a tap tempo, but I guess my case is a bit different...
A friend of mine give me this code
Code: [Select]
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
const int lunghezza = 32;
char pattern1[lunghezza];
char pattern2[lunghezza];
char pattern3[lunghezza];
char pattern4[lunghezza];
const int ledPin = 13;
unsigned char pos = 0;
  pinMode(ledPin, OUTPUT);
  MIDI.begin(3);                         // Lancia il MIDI (su DIN) con input su canale 3
  randomSeed(analogRead(0));
  Ritmo();
void Ritmo()
  Euclide((char *)&pattern1, (map(analogRead(0),0,1023,0,lunghezza)), lunghezza);
  Euclide((char *)&pattern2, (map(analogRead(1),0,1023,0,lunghezza)), lunghezza);
  Euclide((char *)&pattern3, (map(analogRead(2),0,1023,0,lunghezza)), lunghezza);
  Euclide((char *)&pattern4, (map(analogRead(3),0,1023,0,lunghezza)), lunghezza);
  // Euclide((char *)&pattern3, (int)random(5), lunghezza);
void Euclide(char *beat, int colpi, int steps) {
  int cur = steps;
  for (int i=0; i<steps; i++) {
    if (cur >= steps) {
      cur -= steps;
      *beat = 'x';
    else {
      *beat = '.';
    if (colpi==0) *beat = '.';
    beat++;
    cur += colpi;
void on_beat() {
  int velocity= map (analogRead (4),0,1024,0,127);
  MIDI.sendNoteOn(36,0,10);
  MIDI.sendNoteOn(42,0,10);
  MIDI.sendNoteOn(38,0,10);
  MIDI.sendNoteOn(40,0,10);
  digitalWrite(ledPin, LOW);
  if (pattern1[pos] == 'x') {
    MIDI.sendNoteOn(36, velocity, 10);
    digitalWrite(ledPin, HIGH);
  if (pattern2[pos] == 'x') {
    MIDI.sendNoteOn(42, velocity, 10);
  if (pattern3[pos] == 'x') {
    MIDI.sendNoteOn (38, velocity, 10);
  if (pattern4[pos] == 'x') {
    MIDI.sendNoteOn (40, velocity, 10);
  if (++pos == lunghezza) {
    pos = 0;
  for (int i = 1; i < lunghezza; i++)  {
    Ritmo();
    on_beat();
    delay (map(analogRead(5),0,1024,1000,10));
lunghezza is for lenght...
It generates four different patterns for four different midi notes, then I got one pot for velocity and one for the tempo, I would like to insert a sort of tap tempo/looping and activate it with an arcade button. Like an hold and release, if I press it for 4 bars it synchronized the pattern according to the right bpm...
am I clear?
maybe not...
something like that... http://umlautllama.com/projects/arduino/s/TapTempo_WithPressAndHold.pde
