I have been trying to compile this example code from arduino 1.0.6 ide
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 10 (connect to TX of other device)
* TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Serial.begin(57600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("Goodnight moon!");
// set the data rate for the SoftwareSerial port
mySerial.begin(4800);
mySerial.println("Hello, world?");
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
But it doesn't compile the error it shows is like
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::begin(long int)':
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:399: error: 'PCICR' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: 'PCMSK2' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: 'PCMSK0' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: 'PCMSK1' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::end()':
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: 'PCMSK2' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: 'PCMSK0' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: 'PCMSK1' was not declared in this scope
Not only this, even if I try to code any other program using software serial library error is of same manner, tried restarting the pc, tried uninstalling and installing the arduino ide, tried with arduino 1.0.5, but of no avail, any help would be a great relief.
Thanks
