Topic: [Review] The cheapest Arduino Uno R3 compatible: VISduino (Read 24090 times) previous topic - next topic
Peter_n
I bought the cheapest Arduino Uno R3 compatible board for less than 5 dollars/euros, and this is a small review.
The usb-serial chip is a CH340G, that requires an extra driver to be installed (ch341ser.exe from wch.cn).
Plus
  • Extra holes next to every pin so wires can be soldered to it.
  • Another 8 extra holes to solder wires for power, serial and I2C.
  • Pin A6 and A7 are available.
  • Normal size 3.3V regulator, more power for the 3.3V.
  • Enough vias in the ground plane.
  • It is not counterfeit, since they don't claim it is a real Arduino. It is a yellow colored VISduino.
  • The placement of components is accurate.
Minus
  • Some copper traces are very thin.
  • The holes to solder wires could have more copper around it at the bottom side. And they could have more distance to the ground plane.
  • The two larger electrolytic capacitors are the same as on other cheap clones. They could be the cheapest ones around.
  • The soldering is just good enough. A few solder drops/splats are on the bottom. It seems to be a problem with not enough flux or components that are not clean or a working environment that is not clean enough.
  • The USB connector is a micro-USB. I prefer a mini-USB connector.
Conclusion
  • It works !
  • It might be less durable with mechanical vibrations or low temperatures.
  • I would not use it for a project that is running 24 hours a day.
  • It is great for testing.
  • For cheap boards, the conclusion is often that you get what you paid for. Since the 5 dollars/euros for this board on Ebay is inclusive shipping, I think you get more than what you paid for.
nickgammon
Pro: (From the photo) it appears to use a crystal rather than a resonator.
Con: It is a SMD processor, so if you blow it up, it will be hard to replace. But for that price, who cares?
Con: It doesn't look like you can flash the USB chip, but again, that probably doesn't matter.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Also I couldn't find it on eBay:
Quote
0 results found for visduino, so we searched for iduino.
Peter_n
The name VISduino is on the pcb, it was not mentioned on Ebay when I bought it.
Search on Ebay for : arduino uno r3
Select: buy it now
Sort for lowest price for item plus shipping.
Look for the yellow board. My board was not shipped to every country.
The CH340G is used for usb-serial. It just does its job without complaining.
Peter_n
This is at the moment the cheapest Uno R3 compatible board on Ebay.com, and it is a yellow one : http://m.ebay.com/itm/390966031687
Change the 'm.ebay.com' into 'www.ebay.com.au'. The exclude list has "AUS"... :(
nickgammon
I often wonder why some things won't ship here. Are we some sort of backwater?
Peter_n
Well, it works both ways. I tried to buy Vegemite, and it is hard to get in Europe, and has high shipping costs. So I ended up eating two jars Marmite.
nickgammon
GoForSmoke
Might have pesky backwater laws.
Has anyone received one of these or is the analysis based on pictures?
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
GoForSmoke
Seems a bit masochistic.
dannable
Well you do need to be told not to cut the wires with scissors?  :D
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
Coding Badly
Quote
Taxes and/or postal delivery problems are the only things I can think of.
However, your government (like most) does have some oddball restrictions...
Quote
The Australian Government controls the import of certain goods into Australia. The controls include:
- an absolute prohibition, where you are not allowed to import the goods in any circumstances, or
- a restriction, where you need to have written permission in order to import the goods.
Goods bearing an image of the Australian national flag and coat of arms (restricted import)
Items or merchandise (such as souvenirs) containing or which apply a representation of the coat of arms, a flag or a seal of the Commonwealth. This includes a representation closely resembling the coat of arms, a flag or a seal of the Commonwealth, which may be taken as a true 'national symbol'.
vffgaston
Quote
Sorry . . . Where is here?
Regards
Peter_n
vffgaston, Nick lives in Australia, his site ends at "au". He has great tutorials : http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
Shipping to Australia is often more expensive than to us or eu.
I live in Europe and I bought that VISduino board, not because I needed it, but only to see what the cheapest Arduino Uno compatible is like.
nickgammon
Regards
I'm sorry, I forgot that the improved forum has two "(Add Karma)" links on the left of each person's post, but they removed the part that stated what country a poster lived in.
I'm from Australia, the land of Vegemite.
Quote
Was there an Australian flag on the VISduino?
