Topic: CPPM Library for Arduino (Read 5880 times) previous topic - next topic
jmparatte
Jan 29, 2015, 09:56 am Last Edit: Aug 06, 2015, 04:00 pm by jmparatte Reason: Adding French URL
I have written a library for Arduino to interface the CPPM signal of a RC receiver. With it, I can control a small motorized engine with a RC transmitter.
My engine is driven by 2 small dc wheels/motors. Left and right wheels/motors are controlled by PWM pin 5 and 6. The ELEV stick controls the speed and sens of deplacement. The RUDD stick controls the left and right turn and rotation.
The library is documented and explained here: CPPM Library for Arduino
To French readers: La librairie est documentée et expliquée en français ici:  Arduino - CPPM Library
Jimbow
Hello!
I Try your code, and it's dosen't work!!!!
#include "CPPM.h"
// your code...
void setup(void)
  pinMode(11,INPUT);
  CPPM.begin();
void loop(void)
  if (CPPM.synchronized())
    int throttle = CPPM.read(CPPM.THRO);
    digitalWrite(11, !digitalRead(11));    //LED
    Serial.println(throttle);
I see nothing in monitoring
#include "CPPM.h"
I do this because i put .cpp and .h in the same directory
I change in .h the pin interrupt like this because i use an AtMega32u4: INT0 is on pin 5
#define CPPM_ICP1 5
I use an Teensy v2:
My board : https://www.pjrc.com/store/teensy.html
Doc : http://www.atmel.com/images/doc7766.pdf
And my RC is : FRSKY D4RII (It's working on my Naze32 ! )
Thx for help ;)
jmparatte
Hi Jimbow,
I've watched the specifications of the receiver FRSKY D4RII.
It differs from Orange R615X in 2 points:
1/ The synchronization is based on falling edge.
2/ The frame rate is 18ms. So the max number of servos is restricted to 1st 6 of 8 channels (as explained in last red note of manual).
It's why my CPPM library can't synchronize with FRSKY at moment.
I must write some modifications to my library.
At moment, I doesn't own a FrSky equipment, only Orange receivers and Spektrum transmitters.
If somebody based in Switerland can lend me a FrSky D4RII and a transmitter, I could update my library.
You can also try another library, for example: https://github.com/claymation/CPPM
Jimbow
Hi!
I've read your code ^^ and now it 's working!
In first i have do a mistake, interrupt pin (AtMega32u4) for timer 1 is not in pin 5 but in pin 22 ^^
In Seconde, i see in your code :
Line 99
if (CPPM.sync3 < (610 - 16) || CPPM.sync3 > (643 + 16))
I think it's with pulse for a Spektrum (300us) but for FRSKY D4RII it's 400us !
I modified a little your code and i have add in CPPM.h:
#ifndef FRSKY_D4RII
#define WITH_SYNC_PULSE 800 //400us for 0.5us tick timer (16MHz/2)
#define MAX_GAP_PULSE 5088 // 2544 us
#else
#define WITH_SYNC_PULSE 300 //300us
#define MAX_GAP_PULSE 5088 // 2544us for 0.5us tick timer (16MHz/2)
#endif
I have modified the line 99:
if (CPPM.sync3 < WITH_SYNC_PULSE - 30 || CPPM.sync3 > WITH_SYNC_PULSE + 30)
And the line 113:
if(CPPM.sync2 > MAX_GAP_PULSE) // gap pulse ?
note:
I live in france in Haute Savoie not far from Annemasse, i think you are from geneva ^^
jmparatte
Thank you Jimbow for your help.
I will study the AtMega32u4 that I don't know currently.
And integrate your corrections.
And the write() function to generate a CPPM Stream (Arduino pin 9).
I have also written a ATtiny85 CPPM decoder for 4 servos.
note: I live in Neuchâtel. Annecy is not so far.
jmparatte
I've published a new enhanced/reworked revision today.
markfrasca
Thanks. Can you explain how to use it with FRSKY receivers?
markfrasca
OK got this code working with my FrSky D8R-XP receiver. Question is how do I send CPPM output to pin 9?
