Topic: NFC & YUN (Read 9725 times) previous topic - next topic
sonnyyu
Jan 30, 2015, 09:29 am Last Edit: Jan 31, 2015, 06:11 am by sonnyyu
YunOS has very good lib to support NFC, unfortunately it is out date.
libfreefare:0.2.3
libfreefare
libnfc:1.4.2
Libnfc
I backport both lib to current version:
Code: [Select]
cd /mnt/sda1
wget -O  nfc.tar.gz https://www.dropbox.com/s/moyx9otp7fpptzn/nfc.tar.gz?dl=0 --no-check-certificate
tar -zxvf nfc.tar.gz
Code: [Select]
cd nfc
opkg install libnfc_1.7.0-1_ar71xx.ipk
opkg install libnfc-bin_1.7.0-1_ar71xx.ipk
opkg install libnfc-examples_1.7.0-1_ar71xx.ipk
opkg install libfreefare_0.4.0-1_ar71xx.ipk
opkg install libfreefare-examples_0.4.0-1_ar71xx.ipk
Testing with mifare card:
Code: [Select]
root@Arduino:/mnt/sda1# /usr/bin/nfc-poll
/usr/bin/nfc-poll uses libnfc 1.1.0-30-ge81b29b
NFC reader: SCM Micro / SCL3711-NFC&RW opened
NFC device will poll during 30000 ms (20 pollings of 300 ms for 5 modulations)
ISO/IEC 14443A (106 kbps) target:
    ATQA (SENS_RES): 00  04
       UID (NFCID1): d4  b0  48  2f
      SAK (SEL_RES): 08
The User space applications come with libs:
Code: [Select]
/usr/bin/mifare-desfire-access
/usr/bin/mifare-desfire-write-ndef
/usr/bin/mifare-desfire-read-ndef
/usr/bin/mifare-classic-write-ndef
/usr/bin/mifare-desfire-create-ndef
/usr/bin/mifare-desfire-ev1-configure-ats
/usr/bin/mifare-classic-read-ndef
/usr/bin/mifare-desfire-ev1-configure-default-key
/usr/bin/mifare-ultralight-info
/usr/bin/mifare-desfire-format
/usr/bin/mifare-desfire-ev1-configure-random-uid
/usr/bin/mifare-desfire-info
/usr/bin/mifare-classic-format
/usr/bin/nfc-mfultralight
/usr/bin/nfc-mfclassic
/usr/bin/nfc-list
/usr/bin/nfc-emulate-uid
/usr/bin/nfc-anticol
/usr/bin/nfc-poll
/usr/bin/nfc-relay
/usr/bin/nfc-relay-picc
/usr/bin/nfc-dep-target
/usr/bin/nfc-emulate-tag
/usr/bin/nfc-emulate-forum-tag4
/usr/bin/nfc-dep-initiator
The reader is SCM SCL3711:
sonnyyu
Code: [Select]
emulate-tag by Yun and reader
sonnyyu
desfire card
Code: [Select]
New desfire card ev1 card
Code: [Select]
louisbourdon
Thanks sonnyyu for the answer and the tips, but I already have all the hardware I need.
I need to solve the issue of having Yun and my NFC shields communicating together.
And besides, my problem at the moment is that Yun DOES NOT PRINT ANYTHING ON THE SERIAL!!!!!
I can't understand why!!!  Is this a normal behavior or not? Should I return the board?
Is it defective??
sonnyyu
#4
Jan 31, 2015, 06:33 am Last Edit: Feb 24, 2015, 01:44 pm by sonnyyu
  • NFC Forum Type 1  Broadcom Topaz
  • NFC Forum Type 2  Mifare Ultralight, Mifare Ultralight C
  • NFC Forum Type 3  Sony FeliCa
  • NFC Forum Type 4  Mifare Desfire (ev1/ev2), NXP SmartMX with JCOP
Mifare Classic is not an NFC Forum compatible card. It requires NXP's Crypto 1 support that is
only available in NXP reader ICs and crypto keys that are not published in NFC Forum specifications.
NXP SmartMX with JCOP are widely use at e. The e is the next generation of travel documents and has many advantages: It reduces the risk of tampering and identity fraud by adding more layers of identity checks, all of which must match.
You need faster CPU to mange it (Yun is fine.), Arduino would not go far.
sonnyyu
#5
Jan 31, 2015, 06:47 am Last Edit: Jan 31, 2015, 06:48 am by sonnyyu
Last three month NXP semiconductor stock chart.
NXP semiconductor manufactures NFC IC of  SCL3711, Elecfreaks NFC Shield v1.6 as well as Apple Iphone 6.  Iphone 6 is released at 10/2014.
sonnyyu
#6
Feb 24, 2015, 01:40 pm Last Edit: Feb 24, 2015, 01:43 pm by sonnyyu
The list of NXP NFC IC chip:
  • NXP PN531  Obsolete
  • NXP PN532  Most of NFC  shield, if not all.
  • NXP PN533  (SCM SCL3711)
  • NXP PR533
  • NXP PN544
  • NXP PN65N
  • NXP PN65V10 Apple Iphone 6
  • NXP PN7120
Mifare Classic is not an NFC Forum compatible card.  Mifare Classic 1K/4K  is not NFC card!
ALEXS40
Dear All
 I get an error No NFC devise found with a reader SCL011
are there any drivers fro this ?
Thank you in advance
Alex
