Topic: Questions about Arduino spot welder controller (Read 41590 times) previous topic - next topic
avandalen
Feb 02, 2015, 11:32 am Last Edit: Mar 08, 2015, 12:08 pm by avandalen
Read the article of the DIY battery tab resistance fine-spot welder here:
http://www.avdweb.nl/tech-tips/spot-welder.html
Because the electronics and software is too complicated for many people I have made a printed circuit board.
http://www.avdweb.nl/arduino/hardware-interfacing/spot-welder-controller.html
Questions about the spot welder controller can be asked in this topic.
KenF
Interesting.  Just been looking over the software Here
Just wondering what this bit is supposed to be doing.
Code: [Select]
#include
#include  // library
#include  // library
#include  // library
330R
I don't quite understand why you are shorting the two big wires from the transformer. Isn't one end supposed to go to the ground clamp?
avandalen
Code: [Select]
#include
#include  // library
#include  // library
#include  // library
Yes that is weird, long story, but fixed now.
avandalen
It is not shorted.
Henry_Best
#5
Feb 06, 2015, 05:13 am Last Edit: Feb 06, 2015, 05:16 am by Henry_Best
That's an unusual arrangement.
Usually the two arms are diametrically opposed, either vertically or horizontally, so that they can compress the work parts together before sending the current through them.  I can't see how your welder would work without pinching the two work parts together.
See http://www.tool-net.co.uk/p-363291/clarke-csw6t.html?gclid=CNauroS6zMMCFU7KtAodBjgAHQ  for an example.
baxev2005
This electrode arrangment is used for battery tabs welding or other welding tasks, where the access is limited to one side only. Search for battery tab welding and you 'll see why is this done like this.
dwforbes
Hello Albert!
My name is David and I was curious where i can find the <Switch.h> library and the <Albert.h> library.
I found the <Streaming.h> library and I am assuming that the <Arduino.h> library is already installed with my Arduino software program I recently installed on my laptop.  Thank you in advance for your help!!
P.S. I think your spot welder is awsome!!!! Kudos & Accolades!!!
dave-in-nj
interesting.    what is the typical amp load and what thickness of metals can this handle ?
I have wanted to weld battery tabs, but since it is so rare, just buy them pre-welded.
also  wanted to make/weld thermocouples from raw thermocouple wire.
can't wait for the youtube on this.
avandalen
Code: [Select]
#include
#include  // library
#include  // library
#include  // library
This has been changed now
#include <Arduino.h>
#include <Streaming.h> // library
#include <Switch.h> // library
#include <Albert.h> // library
avandalen
Code: [Select]
#include
#include  // library
#include  // library
#include  // library
avandalen
#11
Mar 08, 2015, 11:59 am Last Edit: Mar 08, 2015, 12:00 pm by avandalen
You can see here the Spot welder opposed configuration
The series configuration spot welding is not very common, but always used for welding batteries.
avandalen
#12
Mar 08, 2015, 12:03 pm Last Edit: Mar 08, 2015, 12:04 pm by avandalen
Hello Albert!
Look here:
http://www.avdweb.nl/arduino/troubleshooting.html
avandalen
See here:
http://www.avdweb.nl/tech-tips/spot-welder.html#h7-maximum-welding-thickness
Kingmaury
I mounted the electronics for the spot welder, I turned, but I always 220 V on output to the transformer. I checked and installed all components correctly.It has already happened a problem like this?
Thanks.
