Topic: Speed Control without delay !  (Read 1 time) previous topic - next topic
veliusta
Feb 04, 2015, 03:59 am Last Edit: Feb 04, 2015, 11:24 am by veliusta
With delay Code;
Code: [Select]
const int LEDPin[10] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12};
byte y=0;
long wait=1000;
byte SPEED_MOD=0;
void setup(){
 for(y=0; y<10; y++){
  pinMode(LEDPin[y], OUTPUT);
 pinMode(2, INPUT_PULLUP);
 pinMode(13, OUTPUT);
 attachInterrupt(0, KESME, LOW);
void loop(){
   digitalWrite(LEDPin[y], HIGH);
   delay(wait);
   digitalWrite(LEDPin[y], LOW);
void KESME(){
if(SPEED_MOD == 5){
  SPEED_MOD=0;
  else{
   SPEED_MOD++;
  if(SPEED_MOD == 0){
  wait=1000;
  if(SPEED_MOD == 1){
  wait=700;
  if(SPEED_MOD == 2){
  wait=500;
  if(SPEED_MOD == 3){
  wait=200;
  if(SPEED_MOD == 4){
  wait=100;
  if(SPEED_MOD == 5){
  wait=50;
I want without delay code. How do I make?  :'(
The end time does not pass to the other mode. :'(
nilton61
#1
Feb 04, 2015, 06:15 am Last Edit: Feb 04, 2015, 06:18 am by nilton61
Code: [Select]
const int noLeds = 10;
const int LEDPin[noLeds] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12};
unsigned long mark;
void loop(){
  if(millis()>=mark){//check time mark
    mark += wait;//increase time mark
    digitalWrite(LEDPin[y++], 0);//turn previous led off
    if(y==noLeds) y = 0;//y=y%noLeds
    digitalWrite(LEDPin[y], 1);//turn next led on
  }//if(millis()>=mark)
}//loop()
veliusta
#2
Feb 04, 2015, 08:47 am Last Edit: Feb 04, 2015, 09:31 am by veliusta
Not Worked
Code: [Select]
unsigned long mark;
byte y=0;
long wait=100;
byte SPEED_MOD=0;
void setup(){
void loop(){
void KESME(){
if(SPEED_MOD == 5){
 SPEED_MOD=0;
 else{
  SPEED_MOD++;
 if(SPEED_MOD == 0){
 wait=10000;
 if(SPEED_MOD == 1){
 wait=700;
 if(SPEED_MOD == 2){
 wait=500;
 if(SPEED_MOD == 3){
 wait=200;
 if(SPEED_MOD == 4){
 wait=100;
 if(SPEED_MOD == 5){
 wait=50;
AWOL
Quote
NOT Work
OK, define "work".
Please use code tags when posting code.
nilton61
Since you are using the global y variable in the for() loop in the setup() function y will start at 10 in you code.
Robin2
Not Worked
So what do you think might be the problem.
Thinking is 99% of successful programming.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
nilton61
#6
Feb 04, 2015, 11:01 am Last Edit: Feb 04, 2015, 11:01 am by nilton61
I suggest you make y a local variable in the setup() function:
Code: [Select]
for(int y=0; y<noLeds; y++)pinMode(LEDPin[y], OUTPUT);
veliusta
I did it. No Delay, No millis() :D
Code: [Select]
byte y=0;
long BEKLE=150000;
byte SPEED_MOD=0;
unsigned long DOGRU_ZAMAN;
unsigned long DONGU_ZAMAN;
void setup(){
 y=0;
void loop(){
    DOGRU_ZAMAN = DOGRU_ZAMAN+1;
  if(DOGRU_ZAMAN >= (DONGU_ZAMAN + BEKLE)){
     if(y==0){digitalWrite(LEDPin[9], LOW);}
     digitalWrite(LEDPin[y]-1, LOW);
  if(y == 9){
   y=0;
  }else{
   y++;
    DONGU_ZAMAN = DOGRU_ZAMAN;
void KESME(){
if(SPEED_MOD == 5){
  SPEED_MOD=0;
  else{
   SPEED_MOD++;
  if(SPEED_MOD == 0){
  BEKLE=150000;
  if(SPEED_MOD == 1){
  BEKLE=75000;
  if(SPEED_MOD == 2){
  BEKLE=50000;
  if(SPEED_MOD == 3){
  BEKLE=25000;
  if(SPEED_MOD == 4){
  BEKLE=10000;
  if(SPEED_MOD == 5){
  BEKLE=5000;
nilton61
You should use millis() instead, what you have done is writing your own delay which blocks the cpu and does nothing useful except that is has far worse accuracy.
