i just wanted to understand mosfet datasheets...
My apologies for hijacking your thread.
I have in the past done similar with smaller similar setups.
When it comes to switch mode supplies there is a lot to be considered and it can get complex.
The buck converter mentioned works well with a voltage source.
As already mentioned a voltage source from imag could result in loss of excitation.
A generator is often considered to be a voltage source especially the infinite grid at fixed frequency.
However a generator can be a current source also and your previous mention of experience with variable frequency drives makes me wonder if that has a bearing on what you are trying to do.
A previous argument elsewhere (in depth over many years)indicate that the self excited imag generator is a special case.
I did not understand the maths.
The previous argument involved a proposed current to voltage convertor but the proponent who successfuly did it got the huff with us and would not describe how it worked.
I just used a permanent magnet which worked fine.
Experimenting with pwm regulation could well give you some very difficult to understand results ,some of which could result in flash and bang rather than a whisp of smoke as I previously posted.
There are some here who may be able to help but you would have to post more detail.
A mosfet is a fantastic device for switching large currents with low resistance loss .
When used in switched power supplies there is more to be considered.
I do not think anyone here is being unhelpful but on its own the mosfet is not the only thing to be considered.
Often when people ask for help the assumption is they ask for help because they assume that people here know more , then argue.
It could be that in this instance you are the professor and we just do not know.
edit
I just reread that.
Style was not as intended.
Don't want to sound pompous or so.
But when considering switch mode supplies the power source has to be considered as well as the output.
