Topic: Interfacing GL827 (UTMI) and arduino (USB/SD datalogger) (Read 599 times) previous topic - next topic
Usercore
Hello
I'm starting a project in which i would need a datalogger. I know there is a lot of information about this and cheap solutions to do that, but i've found an old usb/card reader and i was wondering if is possible to interface via UTMI this board to mi arduino (UNO) so i can write to both cards and usb from mi arduino.
The board is almost the same as this:
http://www.ebay.es/itm/CARDREADER-USB-BOARD-FUJITSU-SIEMENS-AMILO-Pi-2530-P-N-35GMP5500-C0-/400651368942
And the chipset it uses is the GL827 48pin. It uses a UTMI communication protocol.
The on-board socket uses 10 pins, i'm sure 2 of them are power supply to the board, other 2 are the usb serial pins and the rest are used by the GL827.
There are two legs by they are driven by a comparator and the chip so i don't think they have dedicated pins on the socket.
I have never used UTMI protocol so i'll need a lot of help with this (not too many datasheets or information about the protocol)
