Topic: Need help using linksprite IR Camera with arduino uno (Read 619 times) previous topic - next topic
ttbccthelegend
I am currently working on a project that will utilize this camera:
https://www.sparkfun.com/products/11610
The code that sparkfun provides is a bit outdated, so after looking a while for updates I currently have the code below. The problem with this however is that it seems as though nothing is happening, and mySerial.available() always ends up as 0 so the loops never do anything. If anyone can please provide some help as to what I can do to get this working I would greatly appreciate it. Thanks everyone.
Code: [Select]
#include <SoftwareSerial.h>
 byte incomingbyte;
 SoftwareSerial mySerial(4,5);                     //RX 4, TX 5
 int a=0x0000,j=0,k=0,count=0;                    //Read Starting address
 uint8_t MH,ML;
 boolean EndFlag=0;
 void SendResetCmd();
 void SendTakePhotoCmd();
 void SendReadDataCmd();
 void StopTakePhotoCmd();
   Serial.begin(19200);
   mySerial.begin(38400);
   Serial.println("Serial has begun");
   //Print what's in the Serial port and Reset
     SendResetCmd();
     Serial.println("Sent Reset Command");
      delay(4000);
      //After reset, wait 2-3 second to send take picture command, check again
           Serial.println("BEfore send tak photo command");
      SendTakePhotoCmd();
           Serial.println("After sendtakephotocommand");
      int numOfSer=mySerial.available();
      Serial.println(numOfSer);
     while(mySerial.available()>0)
        incomingbyte=mySerial.read();
        Serial.println(incomingbyte, HEX);
      byte a[32];
      Serial.println("Byte Array Initialized");
      while(!EndFlag)
        Serial.println("Entering While Loop");
         j=0;
         k=0;
         count=0;
         SendReadDataCmd();
         Serial.println("Read Data Command Sent");
         delay(25);
               k++;
               if((k>5)&&(j<32)&&(!EndFlag))
               a[j]=incomingbyte;
               if((a[j-1]==0xFF)&&(a[j]==0xD9))      //Check if the picture is over
               EndFlag=1;
               j++;
       count++;
          for(j=0;j<count;j++)
          {   if(a[j]<0x10)
              Serial.print("0");
              Serial.print(a[j],HEX);
              Serial.print(" ");
          }                                       //Send jpeg picture over the serial port
     while(1);
 //Send Reset command
void SendResetCmd()
  Serial.println("in send reset cmnd");
      mySerial.write(0x56);
      mySerial.write(byte(0x00));
      mySerial.write(0x26);
//Send take picture command
    Serial.println("in send take photo cmnd");
      mySerial.write(0x36);
      mySerial.write(0x01);
//Read data
     Serial.println("in send read data cmnd");
      MH=a/0x100;
      ML=a%0x100;
      mySerial.write(0x32);
      mySerial.write(0x0c);
      mySerial.write(0x0a);
      mySerial.write(MH);
      mySerial.write(ML);
      mySerial.write(0x20);
      a+=0x20;                            //address increases 32£¬set according to buffer size
     Serial.println("in send stop    take photo cmnd");
      mySerial.write(0x03);
