Topic: 4 cell battery pack is not workin with the servo (Read 348 times) previous topic - next topic
adeel_52
Hi! i need some help . i have bought a servo which works between 6v to 7.4v i used to power it with 4 cell battery pack which gives about 6.2v but servo did not work properly and does not move at the required angle. but then i tried it with a heavy weight 6v single battery of a friend and it works correct. i need some help how i can use 4 cell battery pack because in the robot i cant use that heavy weight battery. Thankx in advance!!!
terryking228
Hmmm. What's your "Current" situation??
- What current does the servo draw when in motion?
- What Cells are you using in your battery? What discharge current are they rated for? Probably best if you have good NiMH cells, well charged.
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
