Topic: "tick tock" sound from a piezoelectric speaker  (Read 4828 times) previous topic - next topic
keith726
I am building a clock and I want to make "tick tock" sounds
using a piezoelectric speaker.
What is the code to produce these sounds?
runaway_pancake
Admittedly, it's not a piezo speaker, but a relay can do a good tick-tock sound.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Grumpy_Mike
You do not get very good quality noises from a piezoelectric speaker even if you have a good quality waveform to give it.
The simplest way would to get a wave shield and play the sounds from that.
el_supremo
Radio station WWV uses a 5 ms long pulse of 1000 Hz (i.e. 5 cycles) to make the sound of a "tick". I tested it with an 8ohm speaker (with 150 ohm resistor in series) and this code:
// Change this to the output pin you are using
#define TICK_PIN 17
  pinMode(TICK_PIN,OUTPUT);
  for(int i = 0;i < 5;i++) {
    tone(TICK_PIN,1000,5);
Sounds pretty good, although 3ms sounds better on the speaker I am using.
Pete
Don't send me technical questions via Private Message.
el_supremo
#4
Feb 09, 2015, 06:51 pm Last Edit: Feb 09, 2015, 06:52 pm by el_supremo
P.S. for a tick-tock sound try this in the for loop:
    tone(TICK_PIN,500,5);
Pete
snorren
Late for the party but just wanted to thank you for the two sounds, fits my piezo buzzers perfect and will be terrific feedback sounds in my menu system!
