Topic: not worked since IDE 1.6.0 (Read 4150 times) previous topic - next topic
alb12
Feb 11, 2015, 12:44 pm Last Edit: Feb 11, 2015, 02:51 pm by alb12
Since I use IDE 1.6.0 I have a problem with my code and I don't understand.
Error:
In function 'void checkTemp()'
internal compiler error: Segmentation fault
Code: [Select]
    #include <OneWire.h>
    #include <DallasTemperature.h>
    #include <Manchester.h>
    #include <stdlib.h>
 //   #include <Time.h>
//    #include <DateTime.h>
//    #include <DateTimeStrings.h>
    // ADD FOR NRF24L01+
    #include <RF24Network.h>
    #include <RF24.h>
    #include <SPI.h>
// ############ UTILISE POUR RECUPERER VALEUR TEMPERATURE EXTERIEUR ###################
String StrTemperatureExt;
float TemperatureExt;
unsigned long difference=0;
unsigned long difference1;
unsigned long time;
unsigned long time1;
float StrToFloat(String str){
  char carray[str.length() + 1]; //determine size of the array
  str.toCharArray(carray, sizeof(carray)); //put str into an array
  return atof(carray);
template <class storageType>
class ValueBuffer
  public:
    ValueBuffer(const int bufferSize, const storageType initValue = 0);
    ~ValueBuffer();
    void operator<<(const storageType input);
    storageType operator[](int wantedN) const;
    void reset(int resetValue);
  private:
    const int _bufferSize;
    storageType* _buffer;
    int _bufferIndex;
ValueBuffer<storageType>::ValueBuffer(const int bufferSize, const storageType initValue)
  _bufferIndex(0), _bufferSize(bufferSize)
  _buffer = (storageType*)calloc(bufferSize, sizeof(storageType));
  for (int i = 0; i < bufferSize; i++)
    _buffer[i] = initValue;
ValueBuffer<storageType>::~ValueBuffer()
  free(_buffer);
void ValueBuffer<storageType>::operator<<(const storageType input)
  _buffer[_bufferIndex] = input;
  if (_bufferIndex == _bufferSize - 1)
    _bufferIndex = 0;
    ++_bufferIndex;
void ValueBuffer<storageType>::reset(int resetValue)
  for (int i = 0; i < _bufferSize; i++)
    _buffer[i] = resetValue;
storageType ValueBuffer<storageType>::operator[](const int wantedN) const
  int index = _bufferIndex - 1;
  if (index - wantedN >= 0)
    return _buffer[index - wantedN];
    return _buffer[index - wantedN + _bufferSize];
//start of program
typedef unsigned short recordtype;
//new buffer with 110 items, fill with 0's
ValueBuffer<recordtype> recording(110, 0);
//todo: move temperature to external file/class
//-4.8:010000010010000001000011000
struct temperatureData {
  unsigned char checksum     : 4;
  unsigned char thirdNumber  : 4;
  unsigned char secondNumber : 4;
  unsigned char firstNumber  : 3;
  unsigned char padding      : 1; // not used, could be used for a "-" boolean in the future
#define IS_IN_RANGE(var,min,max)     (var>min&&var<max)
#define IS_HIGH_PULSE(var)           IS_IN_RANGE(var,1250,1600)
#define IS_LOW_SHORT_PULSE(var)      IS_IN_RANGE(var,150,540)
#define IS_LOW_LONG_PULSE(var)       IS_IN_RANGE(var,1800,2400)
#define SET_BIT(var,bitnum)   (*((unsigned long*)&var) |= 1 << bitnum)
#define CLEAR_BIT(var,bitnum) (*((unsigned long*)&var) &= ~(1 << bitnum))
void checkTemp()  // ############## RECUPERATION DE LA TEMPERATURE EXTERIEUR
  if (recording[0] > 5000 && millis() >= difference1)
    if (IS_HIGH_PULSE(recording[1]) &&
        IS_LOW_SHORT_PULSE(recording[2]) &&
        IS_HIGH_PULSE(recording[3]))
      int bitCount = 0;
      struct temperatureData receivedTemperature;
      //parse the data(from the last pulse to the first pulse)
      for (int i = 4; i <= 107 - 15; i += 2) //+2: skip the highs since high pulses don't differ in length
        if (IS_LOW_LONG_PULSE(recording[i]) && !IS_LOW_SHORT_PULSE(recording[i + 2]))
          //Serial.print(0);
          CLEAR_BIT(receivedTemperature, bitCount);
          bitCount++;
        else if (IS_LOW_LONG_PULSE(recording[i]) &&
                 IS_LOW_SHORT_PULSE(recording[i + 2]) &&
                 IS_LOW_SHORT_PULSE(recording[i + 4]) )
          //Serial.print(1);
          SET_BIT(receivedTemperature, bitCount);
          bitCount++;
          i += 4;
          //Serial.print("DC");
          //Serial.println(recording[i]);
          return;
        if (bitCount == 15) // we got all the bits (was 15)
          StrTemperatureExt = "";
          //                Serial.print("{\"TempExt\":\"");
          Serial.print("Temp_Exterieur:");
          if (IS_LOW_SHORT_PULSE(recording[i + 8]))
            Serial.print('-');
          if (receivedTemperature.firstNumber)
            StrTemperatureExt.concat((String)receivedTemperature.firstNumber);
          StrTemperatureExt.concat((String)receivedTemperature.secondNumber);
          StrTemperatureExt.concat('.');
          StrTemperatureExt.concat((String)receivedTemperature.thirdNumber);
          Serial.println(StrTemperatureExt);
          TemperatureExt = StrToFloat(StrTemperatureExt);
          i = 999;
          time1 = millis();
          difference1 = time1 + 10000;
          return;
    else {
  /*  Receipt_data();*/
void interruptHandler()
  static recordtype previousTime = 0;
  recordtype currentTime = micros();
  recordtype difference = currentTime - previousTime;
  if (difference < 100) //filter noise, received signals should never be shorter than 100(in this case...)
    return;
  recording << difference;
  previousTime = currentTime;
  checkTemp();
  //interrupt for receiving the data, connect receiver to pin 2
  attachInterrupt(0, interruptHandler, CHANGE);
  //attachInterrupt(1,check_state,CHANGE);
  //pinMode(13, OUTPUT);
  difference = millis();
  difference1 = millis();
AWOL
Quote
And that problem is . . ?
alb12
Error:
federicofissore
It looks like a gcc bug. If you remove the -Os flag (optimize for size) it compiles fine. Not something we can handle, though
alb12
Ok, how remove  -Os flag  ?
thanks
federicofissore
you have to change platform.txt, it's a file that describes how the compiler has to be called
however, the compiled sketch won't probably work as expected, since one of the core files (utils/delay.h) requires optimization to be on
I'll ask my colleague for an advice
alb12
Same error after change platform.txt
cmaglie
This is a bug in avr-gcc there is nothing we can do for that (only waiting for avr-gcc developers fix the bug).
Also removing the optimization flag is not going to work, since the delay function rely on that.
@ffissore: the latest avr-gcc shows the same issue?
C.
federicofissore
alb12
Then No solution for this moment ?
federicofissore
Unfortunately, no. I've opened an issue https://github.com/arduino/Arduino/issues/2639 so we may come back as soon as the issue is solved
Vaclav
Error:
Code: [Select]
    #include <stdlib.h>
    #include <RF24.h>
    #include <SPI.h>
unsigned long time;
class ValueBuffer
  public:
    ~ValueBuffer();
  private:
    int _bufferIndex;
  free(_buffer);
    _bufferIndex = 0;
    ++_bufferIndex;
//start of program
      int bitCount = 0;
          //Serial.print(0);
          bitCount++;
          //Serial.print(1);
          bitCount++;
          i += 4;
          return;
            Serial.print('-');
          i = 999;
          time1 = millis();
          return;
    else {
    return;
  checkTemp();
Is this 1.6.0 official release only problem and /or definitely gcc problem ?
I could try to run in on 1.6.0 Nov 4 build if it would help.
federicofissore
alb12
federicofissore
Unfortunately no, there hasn't been a gcc release in the meanwhile
