Topic: Help, first robot confusion (Read 2000 times) previous topic - next topic
Nelhad
Okay so I need to build a robot for my next 4-H club meeting. I decided on a rather large project that seems easy at the same time. I want to build a boxing robot! I just really need to know which arduino, hobby motors, and motor shield to buy. I really only want this project to use two motors so I am basing both of its arms on this design. https://m.youtube.com/watch?v=jS9Ifyjmhrg
Thank you, and if I posted this in the wrong forum let me know!
alka
I don't really want to steer you the wrong way with recommending any specific shields or drivers as they all have their own specific uses and capabilities.
 I will give you a tip.. that boxing arm on the link you posted controlled by a servo. Servos are relatively cheap and easy to control from an arduino. For just two servos you wont even need a shield. Just an arduino and a power source.
Nelhad
I got an Arduino Mega for half at Radio DShack and am ordering some servos soon, thanks for the advice!
Nelhad
Umm okay so if I get two of these servo motors I don't have to get a shield.
https://www.adafruit.com/products/1404
Also how what spots in the Arduino would the wires go in?
zoomkat
Servos need an external power supply similar to below.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
JimboZA
Follow the "learn" link from that page and you'll see: the control wire goes into a digital pin as always and the feedback wire into an analog one.
Most servos don't have that feedback wire.....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Nelhad
So in short will it work or not, and what power supply would you suggest.
Nelhad
Also what is the difference between a continous servo and just a regular servo.
zoomkat
TheOtherGuy9603
I assume by boxing robot you mean it continuously "punches" whatever's placed in front of it. If that's the case I recommend you use a simple dc motor attached to a crankshaft mechanism. You can get gearbox kits to create these types of things rather easily.  :smiley-mr-green:
Nelhad
What do you mean, can you attach a pictures, and you right all I want it to do is continually punch.
Nelhad
Where does the ground wire go from the motor?
