Hello,
Not so much intrinsically Arduino related, but I figure other Arduino users may have encountered this
I have 10 digital servos (all 6v capable and of various but reputable brands) plugged into 2 Arduinos - they are powered via their own supply connected to a DC benchtop supply set at 6v and at full current allowance - the unit is rated at 5A continuous.
If I run all servos at once under moderate load and speeds the supply seems to cope just fine with the current demands.
However, to get it into a running state I have to plug the servos in after having switched on the supply. If I switch it on with all servos plugged in (even if they are at their home positions already), the supply will say it's providing 2.7V at 5A (or whatever I limit the current to on the supply) and the servos wont operate.
It is only when I disconnect around half of the servos before powering the unit on that it will go straight to 6v and display a nice and expected low unloaded holding current when I switch it on (mA's). I can then plug the rest in one by one, and the supply and system operates as I would expect it to, that is, until I switch it off again and the problem starts over.
I get similar behavior with a 6V wall-wart power supply - although I get slightly different numbers probably as the current is limited to 2A on that particular unit.
Questions:
~ Why the 2.7V and seemingly damaging currents upon switch on ?
~ How to get around it? Maybe some kind of electronic version of the 'slowly adding the servos' solution ?
Any help appreciated
