Topic: UsbAsp uploading problems (Read 1 time) previous topic - next topic
gremlinc5
Feb 15, 2015, 03:09 pm Last Edit: Feb 15, 2015, 04:36 pm by gremlinc5
Hi all,
I have some problem. I think my UsbAsp is old because it say when uploadin sketches "Impossible to set SCK, Update UsbAsp Firmware".
So my problem is that UsbAsp could upload only the bootloader. When I program the bootloader all is ok, only sometimes it say that my ATMega 2560 have a bad signature.
But when I upload whatever sketch with UsbAsp, to the ATMega 2560 like Blink example, the led doesn't flash.
If I burn the bootloader with UsbAsp the led flashes for the bootloader. Then if I burn the blink sketch with the standard USB/Serial programmer integrated in the arduino all is ok and the led flashes with different timings.
It seems that UsbAsp could program only the bootloader!  :'(
I need in my sketch all 4 serial ports, how could I do? Do you think that Arduino ISP is better for ATMega 2560? Or I'm missing something related with my hardware?
Thank you.
gremlinc5
My UsbAsp is like this:
USBASP su Ebay
I got Windows 7 64 bit, I'm using Visual Micro to program with under Arduino IDE 1.0
My board is an ATMega 2560 Sunfounder like this:
Sunfounder ATMega 2560
gremlinc5
Solution
I'll get a Atmel MK2 too  :D
My UsbAsp could only program the bootloader too, so it's not my fault  ;)
gremlinc5
I tried to program with UsbAsp a Arduino Nano Compatible and it's done... I think there is an incompatibility between UsbAsp and ATMega 2560 only.
Do you?
CrossRoads
Yes.  Get a real programmer that can properly address the larger memory space of the '2560 chip:
http://store.atmel.com/PartDetail.aspx?q=p:10500054#tc:description
and the other Atmel chips you may use with Arduino.
gremlinc5
 Thank you.
I bought it on Farnell site, I normally buy from them. I'm now programming two chinese Nano with Wire library and them could be programmed with UsbAsp.
gremlinc5
Nop Farnell canceled my order... I have bought it from your link site, thank you.
