Topic: Connecting a DUE to 2 computers (Read 971 times) previous topic - next topic
cowasaki
Has anyone connected the programming USB to one computer and the native USB to another?  I'm developing a game controller and having the programming USB connected to one machine whilst the native is connected to the other computer which is running the game would be very helpful.
MarkT
I would want to check how the power is handled on the board - connecting two different
USB supplies in parallel could be an expensive mistake, since voltage regulators cannot
be paralleled.
MorganS
The power from the two USB ports goes through two MOSFETS before it reaches the 5v rail on the board. One of the MOSFETS is under the control of the chip: the notes on the schematic say that this is to switch off power to the native USB when in host mode.
Since you don't really know where the grounds of your two computers are, connecting them could cause flash-bang-smoke even if the 5v lines are isolated. If one of the computers is a laptop and you can run it on the battery - no connection to mains power - then that would be OK.
"The problem is in the code you didn't post."
MarkT
Quote
Its not host mode that's the issue, its when you parallel the outputs of two 5V regulators you
can get oscillation (large voltage swings)  I lost 5 chips on one board to this through carelessness
once, its something you should never do.
