Topic: Problem , "fatal error: avr/io.h: No such file or directory" (Read 3538 times) previous topic - next topic
assy
i am working with the Arduino Due, using Arduino 1.6.0 and i got this message while compiling
Someone know this problem?
what i need to do?
Thank you, Assy
AWOL
The Due doesn't use the AVR processor.
Quote
Compiling what?
assy
this my code:
Code: [Select]
// avr-libc library includes
#include <avr/io.h>
#include <avr/interrupt.h>
#define LEDPIN 2
    pinMode(LEDPIN, OUTPUT);
    // initialize Timer1
    cli();             // disable global interrupts
    TCCR1A = 0;        // set entire TCCR1A register to 0
    TCCR1B = 0;
    // enable Timer1 overflow interrupt:
    TIMSK1 = (1 << TOIE1);
    // Set CS10 bit so timer runs at clock speed:
    TCCR1B |= (1 << CS10);
    // enable global interrupts:
    sei();
ISR(TIMER1_OVF_vect)
    digitalWrite(LEDPIN, !digitalRead(LEDPIN));
this is the Error message :
compilation terminated.
Error compiling
Moderator edit: And there's your code with CODE TAGS.
AWOL
Code: [Select]
#include <avr/io.h>
Have you ever seen those directives in any other Due sketch?
Have you ever wondered why?
assy
You right , can't do it with the Due board
i changed it to Arduino Mega and everything OK.
Thank you :)
