Topic: Arduino Yun Wifi Hotspot with Ralink RT5370 (Read 5997 times) previous topic - next topic
rockeronline00
I've just bought a wifi dongle with Ralink RT5370 Chipset.
The installation of the related packages was fine and Linino recognized the new dongle.
Code: [Select]
opkg install kmod-rt2800-lib kmod-rt2800-usb kmod-rt2x00-lib kmod-rt2x00-usb
I tried to disable the internal WIFI and enable the new one via Luci Interface and modifying /etc/config/wireless but I didn't solved the problem. My pc tries to connect to the wifi (new dongle interface) but gets no IP. I think it's  Linino's DHCP server problem .   Have you got some tips? Thanks
MS in Computer Science
Drones addicted
Musician and composer
jessemonroy650
::::SNIP::::
@rockeronline00,
Yes. Why are you turning off a perfectly good wifi?
Jesse
rockeronline00
Because I'm building an Arduino Yun-based quadcopter and Arduino's Wifi sucks... only 5 meters -.-
Drones addicted
jessemonroy650
@rockeronline00,
then add an antenna and turn up the power.
Google arudino yun attenna
Connecting external antenna to Arduino Yun
http://forum.arduino.cc/index.php?topic=221945.0
OpenWrt Wireless FAQ
http://wiki.openwrt.org/doc/faq/faq.wireless
Jesse
rockeronline00
Hi Jesse,
thanks but I have already read those posts on external antenna, and as you could see, there's no possibility.
So as I posted above, I'm trying with a dongle Wifi since OpenWrt recognizes it.
My problems come from OpenWrt's DHCP server.. When I enable the dongle (and disable the internal antenna) DHCP doesn't work anymore .
So my PC finds the new network (of the new dongle wifi) but can't connect due to this problem
Drones addicted
sonnyyu
#5
Mar 02, 2015, 10:44 pm Last Edit: Mar 02, 2015, 11:19 pm by sonnyyu
Do it at your own risk!  ( back up your own data)
Code: [Select]
/usr/bin/reset-to-factory-anyway
Code: [Select]
opkg update
Code: [Select]
cd /etc/modules.d
Code: [Select]
mv 24-rt2x00-lib 22-rt2x00-lib
mv 26-rt2x00-usb 23-rt2x00-usb
mv 27-rt2800-lib 24-rt2800-lib
mv 28-rt2800-usb 25-rt2800-usb
reboot Yun
Code: [Select]
mv /etc/config/wireless /var
wifi detect > /etc/config/wireless
Code: [Select]
nano /etc/config/wireless
Code: [Select]
config wifi-device  radio1
option disabled 0
reboot Yun then test
sonnyyu
#6
Mar 02, 2015, 10:55 pm Last Edit: Mar 02, 2015, 11:18 pm by sonnyyu
Tenda W311MI (Ralink RT5370 base USB Adapter)
http://www.amazon.com/Tenda-W311M-150Mbps-Wireless-Adapter/dp/B006GCYAOS
$13.61  2 days free shipping
rockeronline00
Wow  it works !!!  You can't imagine how I'm happy !!!   thank you so much !!
Drones addicted
clynamen
it does not seem to work anymore. The arduino freezes as soon as the wifi dongle is enabled. Did anyone managed to make it work?
sonnyyu
#9
May 10, 2015, 03:46 pm Last Edit: May 11, 2015, 10:03 pm by sonnyyu
Code: [Select]
reboot
is very important.  and follow rest step carefully.
Disable internal radio might help.
Code: [Select]
Code: [Select]
config wifi-device  radio0
option disabled 1
jessemonroy650
@clynamen,
the person with original post did. And several other people also.
Make sure to follow SonnyYu's instructions. Make sure the dongle is on tightly. A loose dongle will cause a weak electrical link and the software will stall and freeze.
Jesse
clynamen
I actually didn't realize the post was so recent, and I though that an update caused a break. Thanks for your information, I'll retry again
ShapeShifter
Actually, although a little kludgey, a low cost solution has been found: http://forum.arduino.cc/index.php?topic=188976.msg2214560#msg2214560
