Topic: GPS U-Blox Neo M8N parser (Read 37595 times) previous topic - next topic
-dev
Quote
would like to see if I can squeeze out more info from the Ublox, for example number of satellites
Yes, the number of satellites can be obtained with the standard NMEA messages (proprietary PUBX messages not required).  If you look at this table, you can see all the fields that are available from standard NMEA messages.
Quote
and whether there is a RTK fix between Base and Rover.
NeoGPS does not parse RTCM messages that (might?) contain this information.  There is a status field in the standard NMEA message GGA that indicates the device has a differential fix (see the "Fix Quality" field #6, in section 29.2.4 of the ublox NEO-M8 Protocol Specification).
There are 2 new values for this field in the NEO-M8 device: RTK_FIXED and RTK_FLOAT.  These would not be recognized by NeoGPS, but I would consider adding them if that is what you are looking for.
Quote
Any suggestions?
Yes, attach the INO file to your post, if you modified it.  And instead of embedding an image of the error messages, press the "Copy Error messages" button in the IDE and paste the text into your post, in between [code]...[/code] tags (like it was code), so...
Code: [Select]
  it looks
    like this.
Otherwise, I think the error message is telling you exactly what to do.
Cheers,
/dev
Really, I used to be /dev.  :(
TegwynTwmffat
Quote
It would be very much appreciated if these fields could be added. Thanks in advance!
-dev
Quote
@TegwynTwmffat, just added these values.  It is not a new release, so you will have to get the latest version directly from github.  See Installation instructions for this manual process.
TegwynTwmffat
Quote
Thank you @-dev ..... I'll get it going tomorrow!
