Topic: Cheap GSM module (SIM800) not connecting to the network (Read 139941 times) previous topic - next topic
kuruki
What power connection do you have?
I have it connected to a 4xAA battery pack with a regulator between them to drop down the voltage to around 4.2 V. I believe it should be giving enough current to work properly. :/
Clemens
You may try out this AT commands:
http://m2msupport.net/m2msupport/sms-at-commands/
There are a lot of other debug examples. Don't know it is helping you.
nikola1010
I have the same problem but also every once and then SIM800L outputs on it's own:
Code: [Select]
+CFUN: 1
+CPIN: READY
Call Ready
SMS Ready
Call Ready
SMS Ready
What could be the issue?
kuruki
I'd get those "Call Ready" and "SMS ready" too sometimes. Glad to know I'm not the only one with the problem. Which country did you try this in if I may ask?
nikola1010
Croatia.
I asked my ebay seller to tell me if they are locked on China network or something, but didn't get any useful information.
nickiskr
I have the same problem.
The module is rebooted and is not registered on the network with newer SIMcard 4G.
Sometimes it works without any problems with old SIMcard 3G.
I'm from Russia. Sim800L.
tomsoft
I got one of these to.
What I see, is that I can not dial , I always have the "no network" error
but:
- I can send and receive SMS
- I have the "ring" signal if I call the SIM
I use a prepaid Orange Sim card for france
Not sure if this hep, would be happy to get more info on this....
oscardec
Hello.
Try changing the position of your sim card.
This is a very common error.
Best regards.
kuruki
That was definitely not it, since the SIM card was getting recognized by the module.
devinger
I also have this problem with a different breakout board. The weird thing is, when I put in a different sim, the module suddenly does work.
karamelo
Well I've received exactly the same module as the youtube video, but looking at the data sheet, it specifically says that the power input should be around 4V-2A, just bought a adjustable DC-DC converter with an LM2596:
http://www.aliexpress.com/item/1pcs-LM2596-LM2596S-DC-DC-3-40V-adjustable-step-down-power-Supply-module-NEW/1116954291.html
The data sheet also mentions that the data lines should have a max voltage of 2.8V. And a suggested circuit for adapting from 3.3V to 2.8V appears on page 31 of the hardware design guide:
http://simcomm2m.com/UploadFile/TechnicalFile/SIM800L_Hardware_Design_V1.00.pdf
So I think that connecting this directly to an arduino possibly isn't the right choice... The power supply doesn't provide enough current and data lines need some circuitry in order to work.
theanat2010
I have the same problem in registration the sim to the network the AT command are working properly until I use AT+cmgs=......
ctrl+z ...send amsg then it return error
I use orange ..jordan network
Egad
I have been working on a home alarm project for a while. I think I can answer some of the questions here on this thread...
Through my work, I have been using this AT-Command manual for Sim800 - https://www.adafruit.com/datasheets/sim800_series_at_command_manual_v1.01.pdf
Code: [Select]
+CFUN: 1
+CPIN: READY
Call Ready
SMS Ready
Call Ready
SMS Ready
For me, this happens when I send an AT-command before the module gets contact with the network. The Call/SMS Ready are then sent as the module connects to the network.
When I wait for the module to connect before I send my first AT-command, I do not get such messages.
I fixed the RX/TX issue by putting a zener to lower the arduino TX signal. Like here: http://wiki.groundlab.cc/doku.php?id=microcontrollersgsm
The other line is good to go; the arduino senses 2.8V signals.
I also got my 4V power source by lowering the arduino 5V with a zener.
I do not really understand, but if you communicate directly with the module (through terminal) there is no way (if there is, I have missed it) to send <ctrl+z> as this is char no.26 (GSM charset)
My workaround was this:   (a slight modification of the SoftwareSerial example)
Code: [Select]
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available()){
    char c = (char)Serial.read();
    if(c == '#')
        mySerial.write((char)26);
        mySerial.write(c);
Hope this will help you!
//Egad
hasard
Don't forget ; character if you try to call:
ATD+7916XXXXXXX;
simonsmart99
Hi All
I have exactly the same problem with a similar module:
http://www.ebay.co.uk/itm/New-SIM800L-GPRS-GSM-Module-SIM-Board-Quadband-L-shape-Antenna-for-MCU-Arduino-/161698611153?hash=item25a5fcffd1
I have a 2Amp 5v regulated supply powering the unit, so no power problems here.
Here is the response I get when trying to register:
AT+COPS=?
+COPS: (2,"vodafone","voda UK","23415"),(3,"T-Mobile","TMO UK","23430"),(3,"O2","O2 -UK","23410"),,(0-4),(0-2)
OK
AT+COPS?
+COPS: 1
OK
And when I try to register to the Vodafone network manually:
AT+COPS=1,0,"vodafone"
ERROR
So it seems very much as if the module is unable to connect to UK networks.
ANY INPUT WOULD BE GREATLY APPRECIATED.
Kind regards
Simon
