Topic: Displaying a Bitmap image on OLED  (Read 13156 times) previous topic - next topic
henrikla
Hello!
I am having some trouble displaying a Bitmap image on my 128x64 Adafruit OLED clone. To be more precise I am having trouble displaying the image when the image is returned from a library.
Usually the Bitmap image (called "Logo" in my code) is defined as a constant before the setup and then displayed using the Adafruit function "display.Bitmap". I have done this in the code below and it works perfectly as I want it to ; but having the entire Bitmap constant in the main code seems a bit messy in my mind.
Code: [Select]
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 12
Adafruit_SSD1306 display(OLED_RESET);
static const unsigned char PROGMEM Logo[] = //128x64 bitmap
{                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x1F, 0xFF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFC, 0x1F, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xF0, 0x7F, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xC1, 0xFF, 0xFF, 0xE1, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x03, 0xFF, 0xFF, 0xC0, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x07, 0xFF, 0xFF, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x0F, 0xFF, 0xFE, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x1F, 0xFF, 0xFC, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x1F, 0xFF, 0xF8, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x3F, 0xFF, 0xF8, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x3F, 0xFF, 0xF0, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x3F, 0xFF, 0xE0, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x3F, 0xFF, 0xE0, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x3F, 0xFF, 0xE0, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x3F, 0xFF, 0xE0, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00,
            0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x3F, 0xFF, 0xE0, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x1F, 0xFF, 0xE0, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x1F, 0xFF, 0xE0, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x0F, 0xFF, 0xF0, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x07, 0xFF, 0xF0, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x07, 0xFF, 0xF8, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x03, 0xFF, 0xF8, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x01, 0xFF, 0xFC, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0xFF, 0xFE, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x7F, 0xFF, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x3F, 0xFF, 0x80, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x3F, 0xFF, 0xC0, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0x1F, 0xFF, 0xC0, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x0F, 0xFF, 0xE0, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x0F, 0xFF, 0xF0, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x07, 0xFF, 0xF0, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x07, 0xFF, 0xF8, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x03, 0xFF, 0xFC, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x03, 0xFF, 0xFC, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x03, 0xFF, 0xFE, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x03, 0xFF, 0xFE, 0x00, 0x7C, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x03, 0xFF, 0xFE, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x03, 0xFF, 0xFE, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x03, 0xFF, 0xFE, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x07, 0xFF, 0xFE, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x07, 0xFF, 0xFE, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x0F, 0xFF, 0xFE, 0x07, 0xE0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x1F, 0xFF, 0xFC, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x3F, 0xFF, 0xF8, 0x1F, 0x80, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x7F, 0xFF, 0xF8, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0xFF, 0xFF, 0xF0, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x81, 0xFF, 0xFF, 0xE0, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE7, 0xFF, 0xFF, 0x83, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xFF, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFC, 0x3F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFC, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  // init done
  display.display(); // show splashscreen
  delay(2000);
  display.clearDisplay();   // clears the screen and buffer
  // miniature bitmap display
  /***display.drawbitmap(XPOS, YPOS, Name of Bitmap, WIDTH, HEIGHT, Color (1=white))***/
  display.drawBitmap(0, 0,  Logo, 128, 64, 1);
  display.display();
I have therefore created a library (called "LOGOS") where there is a function that returns this Bitmap constant when called upon. I have done this in the code below:
Code: [Select]
#include <SPI.h>
#include <Wire.h>
#include <LOGOS.h>
LOGOS LOGOS;
//128x64 bitmap
static const unsigned char PROGMEM Logo[] = { LOGOS.Logo() };
  // init done
  delay(2000);
  display.display();
This is where my problem starts. When it now tries to display the image its all just random dots here and there. I am receiving some values from the function in the library, but its all mixed up or something.  :smiley-confuse:
Do any of you know what's going wrong?
henrikla
Here is the code for the library which i have created:
Header file: LOGOS.h
Code: [Select]
#ifndef LOGOS_h
#define LOGOS_h
#include "Arduino.h"
class LOGOS
public:
LOGOS ();
unsigned char Logo();
private:
//None
}; //End Class LOGOS
#endif
C++ file: LOGOS.cpp
Code: [Select]
#include "LOGOS.h"
LOGOS::LOGOS()
unsigned char LOGOS::Logo()
{ return  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
Archelon
Hello Henrikla, This is a very long shot but I try.
Your BMPs HEX-values are the only ones that I got working on my OLED display. When I try to create/convert my own into HEX-values it just show random pixels. Could you please tell me how you created or converted your bmp and its hex-values? That would make my day, thanks!
//A desperate Arduinoguy who've been searching all over the internet for solutions ;)
henrikla
Hi Archelon,
I just used a "BMP to HEX"-converter to do the job. I think the one I used was called LCD-assistant. It is very important to get the settings right though, especially if you want the program to to convert horizontally or vertically.
Best of luck!
Archelon
#4
Nov 14, 2015, 02:19 pm Last Edit: Nov 14, 2015, 02:20 pm by Archelon
Thank you so much for replying! I never though you would, considering this is kind of a dead thread :)
I've searched through basically every thread on the internet about OLED and arduinos and the solution to my problem was to switch the LCD assistant setting "Vertical" to "Horizontal"... DOH!
The easiest solution is often the best...
Thanks man you made my day!
Never have love on the internet been more important.
cdsmith66
Hey Henrikla, I know this is an old post, but I was wondering if you ever found a solution to your problem. I'm experiencing the same issue.
I went down the same path as you by writing my on library to store bitmap information. I have tried a few of the other suggested solutions, but I'm still getting a scrambled screen.
Any help would be greatly appreciated.
