Topic: Tone(pin, freq, duration) unusable for Morse code (Read 1 time) previous topic - next topic
paynterf
I recently gave a robot the ability to 'speak' Morse code using a small RedBot buzzer.  In Morse code, the ratios between dot, dash, and spacing intervals are very critical, as it is these ratios that allow the human brain and/or Morse processing programs to correctly interpret the sound sequences.
When trying to implement this capability, I ran into problems trying to use the Arduino tone(pin, freq, duration) function.  It appears that the actual duration of the output from the tone() is very much different than the desired time, resulting in completely unreadable Morse code.  In the end, I wound up using tone(), delay(), and noTone() to implement the Morse code audio sequences, and this worked nicely (except that this implementation blocks during the delay period).
I also tried using the NewTone library, thinking it's duration accuracy would be better, but it is essentially identical (at least in terms of duration) to the original tone library.
In the code below, all but the NewTone() implementation is commented out. To generate the other two samples, all I did was uncomment the appropriate line(s) and comment out the rest. I have attached a ZIP file containing three .WMV files to illustrate the differences between using the tone(pin, freq, duration) non-blocking overload and the tone(pin, freq)/delay(duration)/noTone(pin) implementations.
Code: [Select]
void OutputOneDot(int dotmsec, int buzzerpin)
//tone(buzzerpin, BUZZER_FREQ_HZ, dotmsec);
NewTone(buzzerpin, BUZZER_FREQ_HZ, dotmsec);
//tone(buzzerpin, BUZZER_FREQ_HZ);
//delay(dotmsec);
//noTone(buzzerpin);
void OutputOneDash(int dotmsec, int buzzerpin)
//tone(buzzerpin, BUZZER_FREQ_HZ, 3 * dotmsec);
NewTone(buzzerpin, BUZZER_FREQ_HZ, 3 * dotmsec);
//delay(3 * dotmsec);
el_supremo
I had the same problem and also resorted to using tone/delay/noTone.
BTW the tone you are using is around 3000Hz which sounds irritatingly high. I prefer around 800Hz. Give it a try if your buzzer will allow it.
Pete
Don't send me technical questions via Private Message.
paynterf
Pete
Pete,
I also found 3000Hz quite irritating (as did all the cats in the house!), so I changed mine to 1000 ;-)
Regards,
Frank
