Just released Visuino and Visuino Pro - Graphical Development for Arduino - 7_8_3_58 with new builtin Compilation, Upload, Boards and Libraries management and much more...
https://www.visuino.com/download
This is a really big release, and allows directly to compile and upload code without the need to open the Arduino IDE!
Here is what's new:
- Brand new builtin compile and upload support without the need for the Arduino IDE
- Brand new automatic and manual Platforms and Libraries management
- Added Arduino Nano 33 BLE and Arduino Nano 33 BLE Sense support
- Added HTTP Client component
- Added DIY More ESP32 HiGrow support
- Added DIY More ESP8266 Strong support
- Added DIY More NANO Strong support
- Added LIS3MDL 3-Axis Magnetometer
- Added APDS9960 Proximity, Light, RGB, and Gesture Sensor
- Added LPS22HB Pressure sensor
- Added HTS221 Temperature/Humidity sensor
- Added RemoteXY Sound
- Added M5Stack Vibration Motor Unit component
- Added M5Stack Mini Fan Unit component
- Added M5Stack RS485 to TTL Unit component
- Improved PID component
- Improved Speed To Clock/Direction component
- Improved User Interface
- Improved Text Splitter support
- Improved Server Socket implementation
- Improved MQTT support
- Improved I2C EEPROM component
- Improved Arduino DUE support
- Improved Interrupts support - significantly reduced memory usage, and improved speed
- Improved RemoteXY LED support
- Significantly improved Rotary Encoder component
- Improved EVK-NINA-B1 pin mapping
- Improved IDE stability
- Improved Custom Component component
- Significantly faster IDE when working with big projects
The Visuino Pro and the Visuino SDK are also both available for download on the Visuino site:
