Topic: Isolating 0-5VDC voltage reading (Read 980 times) previous topic - next topic
brother6
Mar 10, 2015, 05:57 pm Last Edit: Mar 10, 2015, 06:49 pm by brother6
Hey guys, thought I'd post here to get some help...
Here's my situation:
I want to isolate a sensor reading (basically, 0-5VDC reading) with the HCPL-7520, and I will be reading the value with my microcontroller (in this case, using the arduino board, but could be any other).
Now, here's the application circuit for the HCPL-7520:
And here's the link to the datasheet: http://www.farnell.com/datasheets/1266244.pdf
Here's the circuit, which I modified for my application:
I tried it about 10 minutes ago, and I wasn't getting anything on the output of the circuit.
Did I do something wrong?
Need your help!
Thanks :D
Edit: Accidentally connected Vref to ground instead of Vcc on my breadboard... rookie mistake ^^
I fixed that, but, after reading through the datasheet, turns out it's best for the input to be between the -200mV and +200mV range (for best linearity on output). So I added a voltage divider to bring my 0-5V input to 0-185mV. It is working now, only problem is that my output now varies between 2.48V and 4.32V, instead of 0-5V.
Note that the gain = Vref/0.512
