Topic: Uno clone CH340 as ISP (avrdude: stk500_recv()...) (Read 4047 times) previous topic - next topic
simiae
HI,
is there anybody with win7 and arduino uno ch340, who is able to use it as ISP? I had original uno, fried it (obviously), bought the clone. It worked right out of the box, no problem to upload blink. But I am unable to make it work as ISP to program attiny45. Tried CH341SER drivers, 1.6.1 IDE, no hlep.
avrdude: Version 6.0.1, compiled on Jan 15 2015 at 16:58:43
        Copyright (c) 2007-2009 Joerg Wunsch
        System wide configuration file is "C:\Program Files\Arduino/hardware/tools/avr/etc/avrdude.conf"
        Using Port                    : COM7
        Using Programmer              : stk500v1
        Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
....etc
please help :)
ChilliTronix
I'm not quite sure what you are trying to do. Is there an on line article you are trying to follow?
simiae
I am trying to program attiny45 via arduino uno (following http://highlowtech.org/?p=1695). it was working with my old unoR3, but it is not with my new unoclone with CH340. So, the problem is either in CH340 or I am doing something wrong.
simiae
so I am looking for somebody with Unoclone CH340, who is able to use it as attiny programmer.
johnwasser
Turn on verbose upload logging in "Preferences..."
File->Examples->ArduinoISP
Tools->Board->Arduino UNO
Tools->Port->COM7  (make sure this is correct)
File->Upload
Install a 10 uF capacitor on the Arduino UNO with the positive side of the capacitor going to Reset and the negative side of the capacitor going to Ground.
Wire up the ATtiny45:
ATtiny45UNOATtiny45UNO
1Pin 108+5V
27Pin 13
36Pin 12
4Gnd5Pin 11
Tools->Board->ATtiny45 (internal 8 MHz clock)
Tools->Port->COM7 (same as above)
Tools->Programmer->Arduino as ISP
Tools->Burn Bootloader
If that doesn't work, show use the verbose upload messages.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
simiae
I did that hundred times, on two computers, with 1.0.6 to 1.6.1, cursing whole day. so why not for 101x... ok, I followed your clear and easy steps and what the...it is working   :smiley-eek:  . So I was doing sth wrong, not sure what, I even dont want to know. Thank you so much for your help. You are the man Johnwasser.
And of course, the conclusion is, that You can use Arduino with CH340 as ISP to ATtiny, (if you are not imbecile  :-[ ).
