Topic: SIM900 Quad-band GSM/GPRS Shield and Arduino Uno (Read 5692 times) previous topic - next topic
oscar2015
A few days ago I received the SIM900 Quad-band GSM/GPRS Shield for Arduino. I want to send data from a temperature sensor to a MySQL data base but I can not comunicate the arduino uno with the shield.
I tested the shield following the steps from this link http://www.simpasture.com/36023.html but when I type the letters AT in the serial monitor, I receive nothing.
what is wrong?
thanks in advance.
dannable
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
oscar2015
the shield is this: http://www.ebay.com/itm/SIM900-Quad-band-GSM-GPRS-Shield-for-Arduino-/221176159800
dannable
Yes, I know that one, the TinyOS one. You have changed the pins that SoftwareSerial uses haven't you?
oscar2015
no I havenĀ“t.
what Softwareserial pins uses this shield?
dannable
Set the jumpers to SW, and use
Code: [Select]
SoftwareSerial GPRS(2, 3);
D8 is the software power pin.
oscar2015
I set the pins but I still receive nothing in the serial monitor.
this is the code:
Code: [Select]
//Serial Relay - Arduino will patch a
//serial link between the computer and the GPRS Shield
//at 19200 bps 8-N-1
//Computer is connected to Hardware UART
//GPRS Shield is connected to the Software UART
#include <SoftwareSerial.h>
unsigned char buffer[64];  // buffer array for data receive over serial port
int count=0;               // counter for buffer array
  GPRS.begin(19200);
  Serial.begin(19200);
  if (GPRS.available())
    while(GPRS.available())
      buffer[count++]=GPRS.read();
      if(count == 64)break;
    Serial.write(buffer,count);
    clearBufferArray();
    count = 0;
  if (Serial.available())
    GPRS.write(Serial.read());
void clearBufferArray()
  for (int i=0; i<count;i++)
    buffer[i]=NULL;
oscar2015
Now, I type "AT" in the serial monitor and I receive "AT" but "OK" doesnt appear.
dannable
dannable
oscar2015
hi again.
I tried all what you said but nothing happens and then I tried this code and it works.
Code: [Select]
#include "SIM900.h"
#include "inetGSM.h"
//#include "sms.h"
//#include "call.h"
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to start a connection as client.
InetGSM inet;
//CallGSM call;
//SMSGSM sms;
char msg[50];
int numdata;
char inSerial[50];
int i=0;
boolean started=false;
     //Serial connection.
     Serial.println("GSM Shield testing.");
     //Start configuration of shield with baudrate.
     //For http uses is raccomanded to use 4800 or slower.
     if (gsm.begin(2400)) {
          Serial.println("\nstatus=READY");
          started=true;
     } else Serial.println("\nstatus=IDLE");
     if(started) {
          //GPRS attach, put in order APN, username and password.
          //If no needed auth let them blank.
          if (inet.attachGPRS("internet.wind", "", ""))
               Serial.println("status=ATTACHED");
          else Serial.println("status=ERROR");
          //Read IP address.
          gsm.SimpleWriteln("AT+CIFSR");
          delay(5000);
          //Read until serial buffer is empty.
          gsm.WhileSimpleRead();
          //TCP Client GET, send a GET request to the server and
          //save the reply.
          numdata=inet.httpGET("www.google.com", 80, "/", msg, 50);
          //Print the results.
          Serial.println("\nNumber of data received:");
          Serial.println(numdata);
          Serial.println("\nData received:");
          Serial.println(msg);
     //Read for new byte on serial hardware,
     //and write them on NewSoftSerial.
     serialhwread();
     //Read for new byte on NewSoftSerial.
     serialswread();
void serialhwread()
     i=0;
     if (Serial.available() > 0) {
          while (Serial.available() > 0) {
               inSerial[i]=(Serial.read());
               delay(10);
               i++;
          inSerial[i]='\0';
          if(!strcmp(inSerial,"/END")) {
               Serial.println("_");
               inSerial[0]=0x1a;
               inSerial[1]='\0';
               gsm.SimpleWriteln(inSerial);
          //Send a saved AT command using serial port.
          if(!strcmp(inSerial,"TEST")) {
               Serial.println("SIGNAL QUALITY");
               gsm.SimpleWriteln("AT+CSQ");
          //Read last message saved.
          if(!strcmp(inSerial,"MSG")) {
               Serial.println(inSerial);
          inSerial[0]='\0';
void serialswread()
     gsm.SimpleRead();
I modified the code to insert temperature data from a sensor to a MySQL data base but when it execute
Code: [Select]
inet.httpGET("hostname", 80, "/insert_data.php?Temperature=22.4&Ph=5.5", msg, 50);
the green led of the shield turns off and doesn't upload the data. I use a USB from de pc to supply power to the arduino.
maybe is not enough power?
dannable
All the GPRS shields I have come across can draw up to 2 amps when transmitting. If the voltage drops below a certain level then the SIM900 will automatically shut down.
I strongly suspect you aren't providing enough power.
oscar2015
what do you recommend? DC 9V/1A Power Supply? DC 12V/86mA Power Supply? I am afraid to fry up the arduino
dannable
If that's the selection you have available then the 9 volt supply. Personally I use 5 volt, 2 amp supplies.
oscar2015
Thanks for your help.
I was looking for a 5v 2amp power supply and I found it but the problem continues. I will try the 9v 1amp power supply and then I tell you.
