I've checked YT, still didn't manage, there were some programming stuff about discovery boards and different than arduinoIDE program uploaders, some ST-Link tools,
I have an option on my IDE for upload method as ST-Link, but it shown me a message that it can't connect into st-link device - however windows seen st-link in device manager
The original implementation of the STM32 core project was directed toward the Maple and the Maple Mini clones. The project grew to address a larger population of STM32 boards based on the STM32F103.
The project was never intended to be a "newbie" project as a replacement for the Arduino 8-bit UNO, Mini, Nano, etc. It was intended for more experienced experimenters who for some reason had outgrown the 8-bit capacity but did not want to rush to the Due; that is, an inexpensive alternative based on easy to obtain Chinese clones of the Maple and Maple Mini.
Some of the boards (Maple Mini) support USB programming and connectivity much the same way that the ProMicro (32U4) does - it enumerates itself as a COMx port under the OS. With Windows, this requires drivers to be installed; instructions are in the Github wiki.
Other development boards or boards that do not enumerate to a COMx port are usually programmed using ST-Link which requires that you purchase a programming device that goes into the PC USB port and connects to the ST-Link header on the board. You can read through the long thread on the devices ordered and that worked (or did not work well.) I use Windows can cannot recommend one.
This is very important and I am going to repeat this again: The STM32 core is not a beginner's project and while the core is working there are some serious issues documented on the github wiki. Just as the issue with OneWire did not appear until a few days ago, I am sure there are other issues which will need work-arounds and fixes. BUT, this is a hobby project and there is no guarantee that compatibility will occur - if you order an STM32 board and utilize the core, you need to know that you are on your own and the core is always in flux - as of this week, a few commands from LeafLabs were removed to align more toward the Arduino commands.
Many AVR 3rd party libraries will not work unchanged - consider this a warning. If you do not understand how to hack a library or are not competent to look into a Due or Teensy3.1 library and ferret the logic - avoid the library. You can check here on github to see if the core team has provided a replacement:
Ported-Working libraries for the STM32 (all functions may not work.)When things are found that do not work (not libraries, basic Arduino commands) someone will hopefully have the hardware to validate the issue and the issue will be placed on the github wiki. Roger will address the priority and determine if a workaround or fix will be appropriate - OR, the issue may simply be documented and left the way it is... depending on the impact. There are no guarantees.
Ray
My Projects
