Topic: Multiwii newb can't open Multiwii 2.4 or flash firmware (Read 7023 times) previous topic - next topic
Duhjoker
I'm going by a checklist from Ready to Fly Quads wiki. Here......
http://www.readytoflyquads.com/the-rtf-wiki
First I extracted the files from the Multiwii 2.3 zip file. It says to install but I never get that option it says Run or cancel. So after I ran the program I shut off the computer for a lil over a minute and restarted it and ran the program it started up fine and just to make sure I shut it down again and restarted again after another minute.
The MW 2.3 still starts up fine.
GameR the DIY Arduino powered gaming device that does more...
https://github.com/Duhjoker/GameR-Iot_T3
https://github.com/Duhjoker/GameR-Iot_ESP
AJITnayak
everything seems ok,
Quote
(wouldn't let me download the latest version)
which arduino version you are using.
When you say it wont allow you to install the software it doubt some problem in OS.
I have installed the above IDE winsow7,8 & xp also. so make it properly installed
AMPS
Duhjoker
when I download the.Zip from the MW 2.4 repository it down loads and then I extract the files which it gives itself a folder but I never go through an install process. I just click the exe and a window pops up that asks to run or cancel. But as of now MW 2.3 loads. And all the sketch files are there too.
I downloaded the 1.0.6 version. For some reason the site wouldn't let me download the latest.
AJITnayak
Ok now check your port being detected or not'. ajit.nayak87 skypeID
Please share me the link where you downloaded the Multiwii software.
take snap shot of connection diagram between Multiwii module & PC
https://code.google.com/p/multiwii/
AMPS
Duhjoker
it's same link you posted above. http://Http://Code.google.....etc
We can skype and team view tomorrow if that's ok. It's been a long day and I'm wiped out. I haven't configured team viewer yet but if you want to skype me at duhjoker0077 when your up and ready since we are on different time zones and I should have it set up for you.
 I really appreciate your patience and your help.
AJITnayak
Let me check your issue Today.
I strongly recommended The few things here.
Make ensure connection are diagram with PC & board are proper.
I recommended to purchase Avr pocket programmer if port not detecting
https://www.sparkfun.com/products/9825
I have already send you request on skype. If i am free i will look into your issue . Ping once online.
AMPS
