Topic: Confused by different results on breadboard vs pcb testing (audio/filter values) (Read 6921 times) previous topic - next topic
xl97
A while back, I had some pcb's fab'd..  (think all SMD Arduino and waveshield merged into one board)
and I assembled a couple by hand using some solder paste and a toaster oven..
I purposely left off a few resistors/caps...  so I could test different values there while the pcb was in a breadboard.
some/most were just wires with female ends on it so I could stick a through hole resistor/cap in and test..
when I found values that worked for me (ie: sound decent to my ear)..   so I keep this one in my breadboard for testing in other projects I plan on using this board as the main board.
I then assembled a few other pcb's taking the values I had/have in the breadboard.. and using SMD versions for the final product.
The version in the breadboard sounds MUCH better than the version that has the matching components on-board.. The later sounds like it has the volume to high in certain parts of the audio and distorts.
I'm curious as to why this is?
I took pics to help visualize things..
The pot I have wired to test tweak values/components R5/R6
Testing values for the R8, C18, C21 components  (although in the final board assembly, I am only messing with R5/R6 and R8..  all other smd components on the final board mirror the smd components on the pcb in the breadboard... ie: C18/C21)
took another pcb that had wrong values for R5/R6 and R8.. removed the SMD components there.. and soldered in the same values being used on the breadboard..
R8 = 3.3k
R5 = 7.8k (measured at pot)
R6 = 1.8k (measured at pot)
but the solo board sounds not as good as the board pcb in the breadboard?  I am not clear why though?
Here is a pic of the schematic for that portion as well..
I have also tried a value of 10k at R8 originally..
R5
R6
R8 are the ones of focus..
I have since altered the pcb design and added an SMD pot for components R8 and R5/R6 in hopes of not having to worry about nailing down a specific value for those areas again. :(
Side question:
I got to thinking maybe I fat-fingered a cap somewhere....  how do you check what values the caps are when they are SMD ones?
I'm very non-experienced in the audio department... please keep that in mind. :)
Coding Badly
One problem / difference is that breadboards have a great deal of capacitance between rows.
xl97
wouldnt the multimeter give the true readings though?  since I'm putting the probes on the components n the breadboard/rows.
oh... 'capacitance'..   (I read resistance previously)
the caps I have though are directly to the board (through female terminated wires)  (you can sorta see it in pic #2 I believe..  R8, C18 and C21 are all connected to female ended/terminated wires so I can switch our values quickly while I test)
only R5/R6 are going through a POT on the breadboard.
would just the wires on those two caps be enough to throw things?  and by how much? how can I check?
thanks! :)
Coding Badly
Quote
True.  But there is additional capacitance between every pair of pins you have plugged into the breadboard.  In my experience, there is capacitance between each row and the neighbors up to three rows away.
Quote
and by how much?
Enough to severely interfere with analog input readings.
Quote
how can I check?
I have no idea.  I assume measuring the capacitance would have to be done with nothing connected to the breadboard lest the item plugged into the breadboard would interfere or be damaged.
Wawa
This IC is an oldie with quite a bit of hiss and distortion.
You did decouple the supply with C17-100n. Is that close to the IC. If not, the IC could oscillate.
C17 probably needs a bit of help from an electrolytic cap (~1000uF/10v) if your supply is not "solid" enough.
C20 value depends on the load impedance. 100uF is a bit low for an 8ohm speaker, but ok for 32ohm headphones. I would use a 470u electrolytic unless you only drive 32ohm headphones. Low value makes the bass sound thin.
R5/6 just sets the volume. With a 5volt supply, you quickly run out of "headroom" (clipping/distortion).
Can you run the IC on 9- or 12volt..
C21, with this value, does not affect the sound.
C18 is part of a lowpass filter with -3db at ~3Khz, and -12db at ~12Khz. Quite a lot of high-cut.
At least that is what an LTSpice simulation told me.
C15/R7 does not influence the sound. It just prevents the IC from oscillating.
Leo..
TomGeorge
Can you attach the image of your circuit please.
Its too small to read on screen in your post.
You real chance of finding the solution is to use an oscilloscope.
A capacitance meter or DMM with capacitance measurement on it will help with the SMD caps.
If you are going to do design work, you need to keep an eye out for bits of test gear, even ebay has some suitable meters.
Any reason for SMD?
Thanks Tom........ :)
Everything runs on smoke, let the smoke out, it stops running....
Wawa
Schematic image is 2304x501 px. Big enough.
I can only see it enlarged by dragging it onto my desktop, and them opening it.
Leo..
TomGeorge
Just looking at spec for LM386, they have in some cases a 10uF bypass cap from pin 7 to ground.
Is it possible that in going SMD your track width is causing volt drop to chip supply pins?
Tom...... :)
xl97
Tom...... :)
thanks for the replies.. (I'll try to go through them more once I get to work/break)..
As for the SMD track thoughts...
wouldnt that also be a problem with the PCB that is in the breadboard then?
The same exact pcb..  just has some pins soldered to it.. and place in a breadboard.. so I can easily have space to mock-up other components/parts with it for testing.. before using the same board (without header pins).. and solder directly to it.
I doubt my DMM has a capacitance option.. (what does it look like....[the symbol]?)
I'm still not clear about the breadboard capacitance stuff...   I suppose I could just pull the pcb out of the breadboard... leaving just the pot connected to it.. (or heck even just connecting wires straight to the pot, so nothing is in the breadboard anymore).. and see if it still sounds good..
at that point though...  I'm not sure what could be the problem.. if I am in using the exact same SMD values of the through holes I am testing with?
I appreciate all the suggested values to changes other components too, but I'm not grasping why the current values work and sound good on one board, and not the other then?  If these were the issues.
(all valid things to explore no doubt, and see how things improve or change..etc...  but I'd like to not change things until I can get the two current boards aligned using the same/current values., if that makes sense)
Also as WAWA mentions.. the images should be big enough, not sure what the forum software does to the images.. if I click on them, they open up to bigger images
I am powering the board from a +7.4v Li-Ion pack.
I really am ok with how it sounds IN THE BREADBOARD..  (which is mis-leading, because its really an assembled pcb.. and only in the breadboard for easy prototyping with it)
just cant the standalone version to match the quality.
@WAWA what value to do suggest for C18 then?
@TomGeorge-
SMD to make the footprint as small as it could be to be used in the most variety of projects  (which is mostly , small sci-fi props...etc)
I cut some solder masks on my vinyl cutter, smear some solder paste, populate, pop it into my $17 wal-mart toaster oven and the are done.
thanks guys!  hoping to still get this worked out.. and understand more.
Wawa
Up to you and/or your application. With this value it cuts a fair amount of highs.
Make it smaller, like 4n7 or 2n2, if you want a flatter response.
Leo..
TomGeorge
Check the side rails of the protoboard, they should be continuous from one end of the board to the other, warning warning some are not, they have a break halfway along them.
Quote
C or Cap or uF or mF or nF or the capacitor symbol.
Sorry for asking this (shoot me down in flames if you like)... I see 1,272 posts in your stats.
Hi, what is your electronics, programming, arduino, hardware experience?
Tom........ :)
xl97
@TomGeorge-
1.) The breadboard (that the pcb is set in) does have breaks in it. (but I have jumpers connecting the break in the rails)... although I dont understand what this info is leading toward?
if I take the pcb out of the breadboard.. and just leave the 'wired in' resistors and capacitors..  how much capacitance could those wires give on the C18/C21? the leads are maybe 2in long, if that?
if it still sounds good... (removed from breadboard.. and I am mirroring those same values on aother board.. something else might be wrong then?  (ie: mix up a value on a part somewhere?)
anways.. :)
2.) No harm asking my experience.. its kind of mixed I guess..LOL  I am not a pro or anything close, nor is this my day job.   I guess I get an idea/project in my head and I work towards it, learning what comes with it along the way.
I'm fairly competent when it comes to Arduino's..  general electronics is 'meh' at best.. hardware..probably worse..lol
built several Arduino's and variants to suit my needs (built in micro sd sockets, merged wave shield, run some off internal 8Mhs clock..etc)  some bluetooth enabled stuff.. most of my stuff is for simple fun projects or for props for sci-fi stuff..
random project that led to me learn things like messing with servos, using 7-segment displays (ie: MAX72xx chips), etc..etc..
like these:
*electronics for an iron-man helmet:
https://www.youtube.com/watch?v=cTXt8l2XH-Q
*electronics for some spider-man webshooters (3D printed)
https://www.youtube.com/watch?v=BpxKEWFCCmE
*modified nerf gun for sci-fi/halo junk:
https://www.youtube.com/watch?v=uEFNH2zFVy4
and probably my most elaborate project to date:
e*electronics kit for a StarWars DC-17 gun: (was supposed to mirror the gameplay of StarWars: Republic Commandos....although I have never played it myself)
https://www.youtube.com/watch?v=jj58wl-aT0M
(several pcbs, for RGB led in barrel, 7-segment counter for ammo, MAX72xx for the ammo/bargraph and of course the code)
learned Eagle basics along the way, make my own packages if need be..
make my own solder masks, re-flow..etc   little workshop set-up...
definitely not properly trained or anything!  lol..  (post count is probably all questions!)  haha..
programming is hit or miss...  I am web designer/developer by day.. so the concepts are not new.. but i'm also spoiled in that manner as never have/had to worry about size/space, casting var properly..
hopefully puts things into perspective for you better? this is just a hobby for me.. so wherever the fun takes me! :)
xl97
update:
well I did the reverse..  I actually soldered  some headers onto the 'external board'  (not sure how else to reference it.. the one in the 3rd pic, that I was trying to get it to mirror the audio of the pcb on the breadboard)
sounded terrible still.. (very muffled)...
I took the original pcb that was in the breadboard..  left the pot wired to the breadboard (which shouldnt matter as that is only for R5/R6 (volume)...C18 & C21 are still connected via wires.. -the pcb is NOT in the breadboard, and it sounded great!, loud, crisp...etc..   what the heck?)
The only thing I can think of is, that I messed up and put a wrong value component on the 'bad board' somewhere?  I checked the resistors...and those all match, but no telling what the SMD cap values are, and it they match.  :(
I believe in one of my first schematics I had a value of 100nF for C18...
but in the most current one I have it at 10nF/0.01uF..
What about R8?  I have used 10k down to 2.2k..
If C18 is really the one that has the most effect on the sound quality.. I believe I have been consistent with the 10nF/0.01uF value.. (I have a 103 (10nF) for C18..and a 105 (1.0uF) for C21.. thats what been 'wired' in for the longest time.. and it sounds good...so my other board that sounds crappy must not have a 103 there?
Wawa
Install LTSpice IV (free).
Unzip the attached file, and load that into the program.
Run simulation (running man)
Use the probe on different points in the schematic (single- or doubleclick).
Change values.
Run again.
Leo..
P.S. R4 is the ICs input impedance (datasheet).
xl97
Hi Leo-
thanks.
I have done as requested. (I have wanted to have a reason to learn LTSpice)..
I have it installed, open file, ran simulation, put probe in several places... or even in one spot..change a value ran it.. change a value ran it
I saw the top portion change, to be honest I have no clue what it means, and what I should be adjusting the values to make the above....like?..  (all lines together?)
