I'm a Arduino noob, but I'm trying to make a barn door tracker for astrophotography. I need the stepper to revolve at 1 RPM exactly. I'm using an Uno with the EasyStepper and my motor is a 10V 200 step bipolar stepper 1.8 degrees a step. Pin 8 is Dir and Pin 9 is Step and GND is GND on the Arduino-Easy Driver respectively.
I tried using the directions on the Stepper - Arduino Reference
but they don't seem to work and I'm not sure if that is because I'm using the EasyDriver. I wasn't able to get them to work with or without the motor driver board.
I've been looking on the forums but I haven't seen anyone trying to get a precise low RPM. Can anyone point me to a good post?
I'm really confused about which library to use. I don't need to accelerate, so the AccelStepper seems overkill.
Below is something I based on Tom Igoe's stepper blog. I wish it was this easy, but this moves the motor much slower than 1 RPM.
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 and 9:
Stepper myStepper(stepsPerRevolution, 8, 9);
myStepper.setSpeed(1);
// step 200/60 of a revolution:
myStepper.step(3.3333);
Thanks so much for your responses! I found the EasyStepper does indeed use 1600 microsteps not the 200, but my code still does not work properly. I also came to the same conclusion as rcorr. The stepper libraries are more for position than RPM. Looks like I'll have to dive into the math a little heavier.
I was looking closer at a design by David Hash. On that article is a link to his Reddit page that has a sketch. It is way more complicated than I expected. See sketch at link.
Here is a quick sketch, You will have to adjust the Speed variable for it to track better.
// Barn Door Tracker for astrophotography
// Stepper motor with Easystepper driver
// For evodov
int Dir = 8; // direction pin
int Step = 9; // step pin 9
int PulseStatus = 0; // status of step pin
//Timing Speed
// stepper = 200 steps/revolution
// driver = 8 micro steps depends on you driver board settings
// Total = 200*8= 1600 steps/revolution
// 1rpm = 1600/60sec = 26.666steps per sec
// period 1/x = 0.0375sec
// = 37500 in microsec
unsigned long Speed = 37500; // Ajust for proper speed in your setup
// The Arduino uses a ceramic oscillatior...
unsigned long NextTime = 0; // Timing register
// the setup function runs once when you press reset or power the board
// initialize outputs.
pinMode(Dir, OUTPUT); // Direction output pin
pinMode(Step, OUTPUT); // Step output pin
// change output value
digitalWrite(Dir, HIGH); // Direction - High or Low change for your needs
// the loop function runs over and over again forever
if (micros() > NextTime){
digitalWrite(Step, HIGH); // give high pulse
NextTime += Speed; // reset for next pulse
PulseStatus=1; // update pulse status
if ( PulseStatus & micros() > NextTime - (Speed/2)){ // after half the period make low pulse
digitalWrite(Step, LOW);
PulseStatus=0; // update pulse status
Try this out and if necessary I can add in a variable pot for fine speed adjust.
evodev:
Did you try my simple stepper code from Reply #1. I don't think it would be possible to make it simpler.
