Topic: Servo motors cams, shafts, followers (Read 292 times) previous topic - next topic
nestorb86
I need to build a mechanism to lift things with a servo motor. I've found this: http://technologystudent.com/cams/cam1.htm
I'v already done a simple one with cardboard and wood sticks, but I need something that holds the cam stronger. Right now the cam slips though the shaft when the object being lift is too heavy.
Where can I buy this components (like servocity.com) to assemble the mechanism? Or if the components are there, how do I assemble them?
Thanks,
Any help would be appreciated.
Robin2
I imagine if you have a cam cut from wood or plastic you could fix it securely to the servo arms with a few small screws.
Post a photo of what you have tried - 1024pixels max
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
