Hi to all,
I've reistalled an old Xp PS3 version.
I understand that xp is not supported any more in many ways, but I always worked with arduino without problems.
Not I encounter many ld.exe crash reports.
I installed arduino 1.6.3
I'm asking to myself if xp is not enough updated to work fine with arduino..
there's some way to understand why I receive these crash, symply adding a line or a variable on a scratch?
(one example: I defined an "int a" in a "if cicle" and it worked, but declaring "int a;" on the top of the scratch, instead of doing that in the "if cicle", it gave a crash)
Please help me,
I'm frustrated..
I don't know what's wrong with my xp.. (arduino version? framenet version? java? .. xp not more supported?)
Arduino: 1.6.3 (Windows XP), Board: "Arduino Uno"
C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10603 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\A1.cpp -o C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\A1.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\hooks.c.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\WInterrupts.c.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\wiring.c.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\wiring_analog.c.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\wiring_digital.c.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\wiring_pulse.c.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\wiring_shift.c.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\abi.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\CDC.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\HardwareSerial.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\HardwareSerial0.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\HardwareSerial1.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\HardwareSerial2.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\HardwareSerial3.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\HID.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\IPAddress.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\main.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\new.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\Print.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\Stream.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\Tone.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\USBCore.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\WMath.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\WString.cpp.o
Using previously compiled file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\core.a
C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc -w -Os -Wl,--gc-sections -mmcu=atmega328p -o C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp/A1.cpp.elf C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp\A1.cpp.o C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp/core.a -LC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1553794396625798415.tmp -lm
collect2.exe: error: ld returned 5 exit status
Error compiling.
During compiling the ld.exe crashes:
ld.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
(classic xp windows for crashes).
Tank you..
I still receive many crashes, but I can't understand why..
I pointed out the same problem in the thread "Re: IDE 1.6.1 is now available for download".
Only one sketch of mine, compiling fine with IDE 1.0.x, cannot compile with IDE 1.6.1 (always on Windows XP), interrupting with message "collect2.exe: error: ld returned 5 exit status".
The same sketch, with the same IDE, on another PC with Windows 8.1, compiles fine.
As suggested by Federico, I tried with next versions of IDE, 1.6.2 and 1.6.3, but "the song remains the same"
I also tried disabling every possible software, without success.
The verbose output of IDE 1.6.3 is in the attachment, because it's too long and the forum sw disallows me inserting it in the post.
oldmaker:
I have the same issue with my machine running with XP, I already started another thread. johnwasser was kind to help me compile it his machine without problem which gave me an idea.
I copied the same sketch on my WIN7 machine, and there everything is OK.
So now I have the following:
machine running WIN XP and IDE 1.6.3 -> collect2.exe: error: ld returned 5 exit status
machine running WIN7 and IDE 1.6.0 -> no problem
I guess if the IDE 1.6.3 had an issue, word would be out by now. So that leaves WIN XP as the root cause. But what exactly?
I found another sketch of mine causing the same error, but today I discovered a ridiculous work-around: adding some totally useless global variables, the two sketches compiles OK also with IDE 1.6.x on Win XP:
int y = 0;
int z = 0;
int w = 0;
The first sketch needs at least 3 additional global variables, the second at least 6.
It doesn't matter the name, the type or the values; the only requirement seems to be the number of variables added.
Hi
I have XP sp3 on two computers: a HP desktop and a Dell laptop.
I previously installed v1.6.1 on the desktop: no problems; 1.6.4: non problems.
Yesterday I updated the v1.0.5 (6?) (no problem) on the laptop to 1.6.4 (pasted from the zip):
collect2.exe: error: ld returned 5 exit status.
I've also tried a complete installation of the v1.6.3: the same error.
I have simply pasted v1.6.4 from the zip file without installing: on the desktop is OK, but on the laptop NOT.
I found a third sketch of mine, that was ok with IDE 1.0.6, causing ld.exe crash with IDE 1.6.3.
This sketch needs at least 12 :o additional global variables, obviously all useless.
But this illogical workaround ever works.
Pay attention to avoid variable name duplication !
Confirm problem. In IDE 1.6.0 seems all OK, but in newer IDE (1.6.1, 1.6.3, which i tested) compile failed with "collect2.exe: error: ld returned 5 exit status" error. WinXP SP3.
WOW - really? Several people, including myself, have experienced a problem with the loader (ld.exe) running on Windows XP, and the best we can hope for is to bring forward an older version of ld.exe from earlier builds?
Really?
How do we get the attention of the developers and maintainers to run the bug to ground and fix it?
same problem here (pro mini / mega328 5V 16MHz) but swap of ld.exe definitely doesn't work for me.
Sometime it helps to "restructure" code (seperate compund operators, change sequence of operations) but trying to include Serial.print breaks compilation almost for sure.
1.6.0 doesn't work at all (compilation stops without result or error).
Adding 12 extra global variable worked for me. Weirdly the id has been working fine all day but when I used three nested 'for' loops and two used the same variable by mistake, well the s*** hit the fan. Its like it just couldn't forgive me anymore.
