Paul S,
I successfully achieved floating point tx/rx by converting floating point values to integers. This required I adopt a set precision for the data, multiply by this order of magnitude, and add a value equal to the maximum absolute value of the data to remove the +/- signing requirement. I implemented the code that you presented in this discussion:
http://forum.arduino.cc/index.php?topic=150896.0 , and likewise performed more math to back out my set-precision floats.
The next challenge is the integration with the control system, specifically, getting a servo to actuate according to the error quaternion. The code is getting verbose at this point, so I hope I may effectively outline the issue to you and receive further guidance:
According to your code, once the "SOP" is read, successive values are stored in an array until the "EOP is read, hence we received a packet. I am able to convert these values to variables while the code is populating the array prior to receipt of "EOP", but am not able to pull values from the array after the complete packet is received. The issue may not stem from this portion of code itself, since this code also works in conjunction with the Adafruit_10DOF library, communicating with the sensor via I2C. Which brings me to my second and potentially related issue and the motivation for this post.........
Although I converted these variables while the array is populating AND successfully generated the error quaternion during stable communication AND validated via Serial.print(the output values to the servo), I get no response from the servo when I implement the servo library's write() command.
Please advise.
