Topic: blink a led with push button (Read 11353 times) previous topic - next topic
Keisan
Hello, I am a beginner in Arduino programming.
My request may seem simple, but I do not know how.
Basically, I have an Arduino board, an LED and a push button.
I want to ensure that a first click on the button can blink (loop) an LED, and so, in one second click on this button, the LED will turn off.
So on ...
Thank you really for future help!
(bad english spotted  :-[ )
Grumpy_Mike
Look at the state change detection example in the IDE.
Pedro147
Keisan - Have a look at this and remember "Google is your friend "  8)  http://forum.arduino.cc/index.php?topic=58284.0
http://www.pedroduino.com
UKHeliBob
Here, have this one on me and learn from it
Code: [Select]
const byte buttonPin = A1;
const byte ledPin = 13;
boolean flashing = false;
byte currentButtonState = HIGH;
byte previousButtonState = HIGH;
unsigned long currentTime;
unsigned long onoffStarted;
long flashPeriod = 1000;
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(ledPin, OUTPUT);
  currentButtonState = digitalRead(buttonPin);
  if (currentButtonState != previousButtonState && currentButtonState == LOW)  //button has become pressed
    flashing = !flashing;
  previousButtonState = currentButtonState;          //save the button state for the next check
  if (flashing)
    currentTime = millis();
    if (currentTime - onoffStarted > flashPeriod)  //if the flash period ended ?
      digitalWrite(ledPin, !digitalRead(ledPin));  //flip the state of the LED
      onoffStarted = currentTime;                  //save the time when it occured
    digitalWrite(ledPin, HIGH);  //force the LED off if not flashing
It would be simpler to use delay() for the flashing but that would make it impossible to read the button during the delay().  Note also that the flashing is turned on/off when the button becomes pressed rather than when it is pressed.  It is almost certain that using millis() for timing and detecting the change of button state will be useful in your future programs.  Note also the use of INPUT_PULLUP in setting the pinMode() of the button pin.  This ensures that the pin is always at a known state rather than floating at an uncertain voltage.
Depending on your wiring you may need to change the logic of the LED control portion of the program which assumes that the LED is off when its pin is taken HIGH.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
jameskirk
Hello
UKHeliBob I used the code that you posted and it works Great...
I tried to modify the code to use 2 LED's but I can't get to work properly...
Here is the code that I modified it blinks really dimm...
Code: [Select]
const byte ledPin2 = 12;
long flashPeriod = 150;
long flashPeriod2 = 500;
  pinMode(ledPin2, OUTPUT);
  if (flashing)
    if (currentTime - onoffStarted > flashPeriod2)  //if the flash period ended ?
    digitalWrite(ledPin2, !digitalRead(ledPin2));  //flip the state of the LED
    digitalWrite(ledPin, LOW);  //force the LED off if not flashing
  digitalWrite(ledPin2, LOW);  //force the LED off if not flashing
Here is a short video...
Video
Thanks
Grumpy_Mike
Quote
How exactly do you mean?
Quote
That code is all mangled up in it's logic. Do currentTime = millis() only once in the loop.
UKHeliBob
Quote
What do you want the two LEDs to do ?  Flash at different rates perhaps ?
jameskirk
Yes flash at different rates...
Thanks
UKHeliBob
OK.  Start with my code and as a crude way of doing what you want, copy the code in the if (flashing) block, paste it back in the block, change the names of all the variables and use a different value for the new flashPeriod variable.  There are neater ways to do it using arrays but get it working in any way you can first.
jameskirk
#9
Jun 12, 2015, 06:25 pm Last Edit: Jun 12, 2015, 06:28 pm by jameskirk
I redid the code and got rid of most of the errors...
Code: [Select]
  if (flashing)
    digitalWrite(ledPin2, HIGH);  //force the LED off if not flashing
Except these errors...
Arduino: 1.6.3 (Windows 7), Board: "Arduino Nano, ATmega328"
Build options changed, rebuilding all
sketch_jun12a.ino: In function 'void loop()':
sketch_jun12a.ino:48:1: error: expected '}' at end of input
Error compiling.
Any suggestions?
Thanks
CrossRoads
Put one more } at the very end to mate with this one:
CrossRoads
If you do Ctrl-T, t it will let you know of mis-matched () and {} also.
You can click your cursor to the right of ) and } and use the scroll bar to see where the mating ( and { is.
UKHeliBob
Or double click to the right of a { or a } and have the whole code block that it encloses highlighted
jameskirk
OK I got the errors fixed but only LED 1 will light up and blink...
Here is the code and a short video...
Code: [Select]
long flashPeriod = 300;
  if (flashing)
Video
CrossRoads
Code: [Select]
You'll only have a few microseconds between the 2 time comparisons, not hundreds of milliSeconds. So the code will do the first write, not the 2nd, and spend the other time turning them both off.
You need to use a "state" tracker:
bothOff
1on,
2on
psuedocode example:
Code: [Select]
void setup(){
state = bothOff
void loop(){
if (state==bothOff & time to turn 1 on met){
// same time tracking you had above, just added the "state" test
turn on 1
state = 1on
set 1 turn off time
if (state==1on & 1 turn off time met){
turn off 1
turn on 2
state = 2on
set 2 turn off time
if (state==2on and 2 turn off time met){
turn off 2
state = both off
set 1 turn on time
} // end loop
