jessemonroy650:
if you scroll, it's
$1 (get a thank you),
$10 (get a board; 82 of 100 left)
$19 (board, ether, USB ; 13 of 100 left)
Thanks - I was not looking at the RHS of the page.
As far as I can see you need a QI to match a Yun and they are down as $37 for "early bird" contributors
That is certainly much better than the price of Yun. But I presume it is a discounted price. What will be the long term retail price including delivery?
Robin2:
...R
Hi, I am Alfie from Domino team. The long-term price including delivery will not exceed $50 for sure. We are working on that.
alzhao:
Raspberry Pi is a different board, if you have to compare with RaspberryPi, the Domino Pi basic only $19 now!
If, as you seem to imply, a Domino PI basic is exactly equivalent in capability to a RaspberryPI then the QI pricing looks like blatant profiteering taking advantage of the (silly) high price of the Yun.
I know a Yun and a PI are not identical. But they each have features that the other lacks so I don't see, taken overall, why they should not retail at about the same price.
Robin2:
...R
The Domino Pi basic is the equivalent of a router such as the TP-Link TL-WR703N, based on the same SoC, i.e., it is a 400MHz-class 32-bit MIPS CPU with 64 MB DDR2 RAM and 16 MB SPI Flash, whereas the RPi is >800MHz, > 256MB DDR2 RAM and no Flash except SDCard. But The Domino Pi only consumes 1/2W and has built-in Wi-Fi and up to 3x Ethernet 10/100MB with integrated switch... So these 2 are not equivalent, but fills some overlapping needs.
As for the Qi, it includes an additional ATMega32U4 (list price $3.50 / 1000 pieces), some expensive voltage level translators, plus it requires dual-sided component mounting, which is also more expensive. It happened that we reached 1/2 of the price of the Yun, but that is just a coincidence, it was not a target
You may rather wonder why the Yun is twice as expensive, given the quantity they are selling
Robin2:
I see no reason for the Yun to be more expensive than a Pi.
Why do they charge more for a Yun? Because they CAN!
The cost of the parts, and the cost to manufacture, only sets the minimum selling price at which they can make a profit. Volume and production methods do enter into that formula. But it does not set the actual selling price. That is set by the perceived value to the potential customer, and the selling price is whatever the market will bear.
