Topic: TFT Extension Version 2 (Read 19830 times) previous topic - next topic
ghlawrence2000
Hi Andrew,
Probably a stupid question, but what should the swipeandslider example do? The blue&orange slider works, but the 4 empty rectangles apparently do nothing?
Cheers,
Graham
UTFT_SdRaw now included in library manager!! ;) High speed image drawing from SD card to UTFT displays for Mega & DUE.
UTFT_GHL - a VASTLY upgraded version of UTFT_CTE. Coming soon to a TFT near you! 8) Shipping April 1 2016!
HazardsMind
Each box should have a number in it, and swiping up or down will change the number accordingly
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
HazardsMind
#77
Aug 14, 2016, 11:33 pm Last Edit: Aug 16, 2016, 01:39 am by HazardsMind
I found the issue, the color for the text is gotten from the slider. However when I changed the code, I forgot to return the slider value. I will post the fixed code. Give me one second.
ps. I haven't had any interest in my arduino projects as I have been more into learning Swift 3 for iOS.
My GitHub:
ghlawrence2000
Hi Andrew,
Well thank you for the update, that has indeed fixed one of the problems, we now have a variable number -1 to 65535 under the slider but the '0, 0, 0, 0 Too Low' never changes regardless of slider.
Sorry you have lost interest in Arduino!
Regards,
Graham
HazardsMind
#79
Aug 15, 2016, 06:32 pm Last Edit: Aug 16, 2016, 01:40 am by HazardsMind
The textcolor is currently set to change when you swipe.
Originally the color was fixed to white but at the last minute I thought it would be good to use the slider to change the text color.
I'll fix the example when I get home.
It's not really that I lost interest in Arduino, it's just I'm an iOS app developer and I code all day. So the last thing I want to do is come home and code some more. Once in a while I'll work on some things on the weekend for my RCs.
Library updated. (there are probably other examples that are not updated, i'll go through, find and fix them too.)
My GitHub:
mpl1337
hi,
I have a issue.
I have created 3 Sliders
Code: [Select]
  slideR.Coords(80, 100, 600, 170);
  slideR.Colors(BLACK, RED, ROUNDED, FILL);
  slideR.SetDirection(LTR);
  slideR.SetRange(0, 1023, 1);
  slideR.SetStartingValue(512);
  slideG.Coords(80, 190, 600, 260);
  slideG.Colors(BLACK, GREEN, ROUNDED, FILL);
  slideG.SetDirection(LTR);
  slideG.SetRange(0, 1023, 1);
  slideG.SetStartingValue(512);
  slideB.Coords(80, 280, 600, 350);
  slideB.Colors(BLACK, BLUE, ROUNDED, FILL);
  slideB.SetDirection(LTR);
  slideB.SetRange(0, 1023, 1);
  slideB.SetStartingValue(512);
  slideR.Draw();
  slideG.Draw();
  slideB.Draw();
  myGLCD.setColor(WHITE);
  if (redraw == 1) {
  slideR.ReDraw();
  slideG.ReDraw();
  slideB.ReDraw();
  Serial.println("redraw slider");
    redraw = 0;
redraw is set to 1 by calling the page function
but when i change the page on my TFT and go back to the Sliderpage then missing the border.
is it possible to fix this?
HazardsMind
Call the unlock method first. If that still does not work, I will look into it
My GitHub:
mpl1337
Yes, Thx it works :) perfect
