Topic: 4 Digit 7 Segment Serial LED Module - TM74HC595 (Read 39423 times) previous topic - next topic
blahop
@NickGammon thanks for the links!
(I may be wrong but it seems that the first link is "only the 7segment display", not with the MAX7219).
What I would need now is a kit (presoldered or not presoldered) with : MAX7219 + board (for 4 digits only) + 4digits 7segment display.
The 8digit board won't fit in my enclosure...
Any idea?
nickgammon
Search eBay? Something like this:
http://www.ebay.com/itm/I2C-4-Digit-7-Seven-Segment-Display-Arduino-uController-5V-Choose-Red-or-Green-/231556862719 That's $8 rather than $3, but you don't always find exactly what you want. Or get one of the 8-digits ones which are not assembled and just not solder on the second 4-digit LED module.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Mitschgel
So has anyone an answer to my question from page 5?
Thanks a lot!
@aarg: I have one question remaining.
The project I'm currently working on is basically a DMX controlled Infrared Remote.
(DMX Reception and sending Infrared Commands is already working great, but I wanted to add the 7segment display to show the current DMX Adress of my Device.)
The DMX signal reception is using Timer2 ( for reference: the DMX code can be found here:  receive-dmx-512-with-an-arduino)
and i have successfully added my 7segment display with your micros() based code.
Since I have unfortunately not much experience with arduino programming and all the timer based ISR stuff is a bit confusing, too...
is it advisable to leave the 7segment display output micros() based or should one better be working with your new timer2 based code?
In this case, I guess that I would have to switch your code from timer2 to timer1,
which I already tried (out of curiosity) and failed totally at :D
aarg
Thanks a lot!
I am just learning the timers. But it seems to me, it must be easy to change to timer 1 from timer 2. I will investigate and post a solution if I find it.
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
aarg
#79
May 18, 2015, 09:13 am Last Edit: May 18, 2015, 12:08 pm by aarg
@Mitschgel. Okay, here is a version that will work with either timer 1 or timer 2. There's a #define variable near the top, you just set it to 1 or 2 to choose the timer.
Mitschgel
wow, thanks a lot
that is just awesome! I'll try to implement it in my project and will let you know how it goes.
thx again for your effort!
2leon76
What about 8 digit display based on 595 chip?
I have found code below -
Code: [Select]
#define LATCH  12  //pin 12 of BBFuino connect to RCK of 8x7segment module
#define CLOCK  11  //pin 11 of BBFuino connect to SCK of 8x7segment module
#define DATA   10  //pin 10 of BBFuino connect to DIO of 8x7segment module
#define LED    13  //LED is connected to pin 13 of Arduino
#define  MultiplexDelay  1  //delay for multiplexing between digit on 8x7segment module
#define LEFT   0  // define the value for left justify
#define RIGHT  1  // define the value for right justify
#define BLANK 11  //array element to make 7segment blank
// array to activate particular digit on the 8x7segment module
// it is the common anode of 7 segment
byte anode[8] = { 0b10000000,  //digit 1 from right
                    0b01000000,  //digit 2 from right
                    0b00100000,  //digit 3 from right
                    0b00010000,  //digit 4 from right
                    0b00001000,  //digit 5 from right
                    0b00000100,  //digit 6 from right
                    0b00000010,  //digit 7 from right
                    0b00000001   //digit 8 from right
//array for decimal number, it is the cathode, please refer to the datasheet.
//therefore a logic low will activete the particular segment
                    //PGFEDCBA, segment on 7 segment, P is the dot
byte cathode[12] = {0b11000000,  // 0
                    0b11111001,  // 1
                    0b10100100,  // 2
                    0b10110000,  // 3
                    0b10011001,  // 4
                    0b10010010,  // 5
                    0b10000010,  // 6
                    0b11111000,  // 7
                    0b10000000,  // 8
                    0b10010000,  // 9
                    0b01111111,  //dot
                    0b11111111   //blank
//fucntion to send the serial data out to two 74HC595 serial to parallel shift register and activate the 7 segment.
void display8x7segment(byte datapin, byte clockpin, byte latchpin, byte digit, byte number)
    digitalWrite(latchpin, LOW);
    shiftOut(datapin, clockpin, MSBFIRST, digit); // clears the right display
    shiftOut(datapin, clockpin, MSBFIRST, number); // clears the left display
    digitalWrite(latchpin, HIGH);
//function to display value on 8x7 segment display according to the justify state
void displayNumber8x7segment(byte justify, unsigned long value)
   byte decimal[8] = {0};
   value = value % 100000000;  //ensure the value is within 8 digits only
   decimal[7] = value / 10000000;  //extract digit 7 from value
   value = value % 10000000;       //extract the rest of 7 digit value
   decimal[6] = value / 1000000;
   value = value % 1000000;
   decimal[5] = value / 100000;
   value = value % 100000;
   decimal[4] = value / 10000;
   value = value % 10000;
   decimal[3] = value / 1000;
   value = value % 1000;
   decimal[2] = value / 100;
   value = value % 100;
   decimal[1] = value / 10;
   decimal[0] = value % 10;
   byte zero = 0;
   if (justify == RIGHT)
     for(byte e = 8; e > 0 ; e --)
       if(zero == 0)
         if(decimal[e-1] != 0)
           display8x7segment(DATA, CLOCK, LATCH, anode[e-1], cathode[decimal[e-1]]);
           zero = 1;
       else display8x7segment(DATA, CLOCK, LATCH, anode[e-1], cathode[decimal[e-1]]);
     delay(MultiplexDelay);
   else  //if justify == left
     byte d = 0;
     for(byte e = 8; e > 0; e --)
       if(zero == 0)
           display8x7segment(DATA, CLOCK, LATCH, anode[7], cathode[decimal[e-1]]);
           zero = 1;
           d ++;
         display8x7segment(DATA, CLOCK, LATCH, anode[7-d], cathode[decimal[e-1]]);
         d ++;
  pinMode(LATCH, OUTPUT);
  pinMode(CLOCK, OUTPUT);
  pinMode(DATA, OUTPUT);
  pinMode(LED, OUTPUT);
  digitalWrite(LATCH, HIGH);
  digitalWrite(LED, LOW);  //off LED
  // set up the LCD's number of columns and rows:
  delay(1000);  //delay for 1 second
void loop(){
  //1st demo, 8x7segment will display decimal value from 0 to 9 and dot from 1st digit (most right) until the last digit (most right)
  for(byte i = 0; i < 8; i++)
    for(byte k = 0; k < 11; k++)
       display8x7segment(DATA, CLOCK, LATCH, anode[i], cathode[k]);
       delay(300);
  delay(1000);  //delay 1 second
  //2nd demo, 8x7segment will display same decimal from 0 to 9 and dot across all 8 digit
        display8x7segment(DATA, CLOCK, LATCH, 0xff, cathode[k]);  //activate all digit
        delay(300);
  //3rd demo, 8x7segment will display a decimal value increasing like normal counter.
  for (unsigned long value = 0; value < 100000000; value ++)
     for(byte i = 0; i < 10 ; i ++)
      displayNumber8x7segment(RIGHT, value);  //display the value in right justify format
407charlie
  I'm trying to get the datasheet but without success. Would you mind to shear it with me?
aarg
#83
Jan 17, 2016, 02:56 pm Last Edit: Jan 17, 2016, 03:00 pm by aarg
What a crazy hijack! Not even a mention of what hardware. And then it gets a response! Oy!
Oliver0nArduino
Thank you aarg, for your research on this and your code. Here is my small contribution, please excuse my style, these were the first lines that I wrote in this environment. :)
It allows one to display a rational number within certain limits
Code: [Select]
int getFullNumberAndCountDecimals(float fNumber, int* decimals){
   *decimals = 0;
   float tempNumber = fNumber;
   while (tempNumber != trunc(tempNumber)){
    tempNumber *= 10;
    *decimals+=1;
   //TODO ignore last digits for numbers that don't fit (like 88.222)
   return tempNumber;
void printRational(float value){
 int countDecimals;
 int fullNumber = getFullNumberAndCountDecimals(value, &countDecimals);
 modulePrint2(fullNumber,10,testDigits);
 testDigits[(numDigits-1)-countDecimals]|= 0x80;
One can use it by calling printRational with the desired value.
nickgammon
These last few posts seem completely off topic to me. What are you thinking of?
nickgammon
I think I'll close this thread before someone starts talking about how to cook chickens. ;)
