If your transmitter emits a pulse every 29us, then your receivers will receive a pulse every 29us, whether they are 10cm away or a mile away.
Ahh, yes that makes sense. I was thinking that an initial sync would fix that - just hadn't figured out yet how I could achieve this without knowing anything from the transmitter except that it is emitting a 40Khz wave at 29us. What if I set something up a sync so that when the transmitter begins its movement I have a counter to see how many pulses were detected and a timer so that I know how many pulses should have been emitted.
ie. if the timer has been running for 1000us I know that there should have been 34 pulses, but if my pulse counter is only at 32 pulses that means the last pulse was sent at 928us. So that tells us this pulse took 72us to travel to the receiver.
The way that I would synchronize the running timer using the millis() function. Tell my arduino, wait for the first pulse, once you have that first pulse get millis() and store the value as the millis() offset. Now every pulse after that I get use millis() subtract out the offset value and I have my run time since the first pulse.
Again, in theory this sounds doable.
And the period of one 40kHz cycle is. . . ?
Would the period matter if I am just checking for a pulse? It would seem like a better idea to use a period of 1 40Khz cycle. I don't know how to do that, but I suspect I will most likely try to achieve this with a 555 timer.
