Topic: Arduino Uno- help with coding two DC motors, one after the other (Read 1 time) previous topic - next topic
haleys92
Hi, everyone. I am in the process of building a "fire extinguishing robot" which basically should drive straight forward for ten feet, stop, and then flip on a fan motor to extinguish a candle mounted at 1 foot off the ground.
I have constructed the robot, however am having difficulty with the code. ( I know it should be simple, however I am new to the robotics as well as the code behind the robot.) The code I have right now is as follows, it will run two DC motors that i have wired into one set of +/- wires to fit into port A on the Arduino Uno. After it runs these motors for a certain amount of time, it will stop them, and then loop again.
My goal however, is to get port A to run the wheel motors, stop them, and then directly after they have been stopped, to start the port B fan motor which will hopefully run for about 10 seconds and then turn off.
I am worried that if I input Port B code directly after I have put a delay on Port A for x amount of time, the robot will wait x amount of time and then begin to run the tire motors again.
You can probably tell I am very confused, and any help would be greatly appreciated! Thanks  ;)
My current code...
  //Setup Channel A
  pinMode(12, OUTPUT); //Initiates Motor Channel A pin
  pinMode(9, OUTPUT); //Initiates Brake Channel A pin
  pinMode(8, OUTPUT); // hopefully initiates channel b motor pin
  pinMode(13, OUTPUT); //hopefully initiates channel b brake pin
 //forward @ full speed
  digitalWrite(12, HIGH); //Establishes forward direction of Channel A
  digitalWrite(9, LOW);   //Disengage the Brake for Channel A
  analogWrite(3, 255);   //Spins the motor on Channel A at full speed
  delay(45000); //milliseconds
  digitalWrite(9, HIGH); //Engage the Brake for Channel A
  delay(10000000);
  // worried fan won't start until 10,000 seconds after motor stops, but we want the motor
  //to stop then immediately turn the fan on and then stop the fan about 10-15 seconds later, and NOT LOOP THE PROGRAM
MarkT
It you want the program to run once, code it in setup(), not loop ().
If you want it to run repeatedly, but wait for a particular condition before
restarting, you'll have to code for that condition, otherwise loop() will just loop().
Long values should be notated as long - on the Uno integers default to 16 bit, so large
values ought to be written as explicitly long:
Code: [Select]
  delay(45000L); //milliseconds
  delay(10000000L);
You can also stop the program progressing further by infinite loop:
Code: [Select]
  while (true) {}
TomGeorge
What arduino controller are you using?
What are you using to control the motors?
How are the arduino and motors powered?
Can you please post a copy of your sketch, using code tags?
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom..... :)
Everything runs on smoke, let the smoke out, it stops running....
