I just upgraded to Ubuntu v15.04 64 bit and am having problems saving sketches. When I load a sketch, all is ok until I want to save it. When I select "File - Save As", the IDE crashes and aborts. In some tries, it locks up with a blank "Save As" window.
I tried with IDE v1.0.5 and v1.6.3 with the same results. It worked fine with Ubuntu v14.10 64 bit.
I am starting to regret upgrading the Ubuntu OS. Anyone else experiencing this?
edit: It does OK if I run as root. The IDE menu bar changes also when run as root.
It generates an error log. I attached a txt version of the last log it generated.
When run as user, it displays this message.
Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar
When run as root, it doesn't.
