Topic: VGA library for Arduino UNO and ATMega328 (Read 35702 times) previous topic - next topic
smaffer
Hello everyone,
i've created a VGA library for Arduino UNO.
Here you can download it.
The library implement a 120x60px framebuffer where each pixel is stored as 2 bits (4 colors). The framebuffer is stored inside SRAM.
The 4 colors generated from the library are not predefined.
You can connect two of the VGA connector pins in different ways, selecting the color combination that you prefer.
To use this library you need only 4 resistors and one DSUB15 connector.
Based on the VGA color video generation by Nick Gammon.
Inspired from the game Toorums Quest by Peten Paja.
AVR interrupt dejitter from Charles CNLOHR.
Happy Hacking!!
mcnobby
#1
May 03, 2015, 07:29 am Last Edit: May 03, 2015, 07:29 am by mcnobby
Excellent !!
I also tried colour but I had a tiny jitter problem which I couldnt find a way to solve
One of the 8 colour drivers I did was for the ATTiny13A (amongst others)
Forum Post
youTube Video
you can see the jitter problem near the end of the video
Cheers :)
smaffer
Hi Mcnobby,
your ATTINY project is great!
I've seen the video and your sourcecode.
The problem can be a little jitter in the execution of your interrupt function (1clock or more of delay that depends on the instruction that is in execution when the interrupt happens)  . I have got a similar problem but in my case the signal was more disaligned (1pixel or more).
I've saw this video by Charles CNLOHR before i realized the problem.
Otherwise can be a clock problem.. Have you looked the signal with an oscilloscope? It's ok?
mcnobby
#3
May 03, 2015, 10:38 am Last Edit: May 03, 2015, 10:38 am by mcnobby
Thanks very much, I just like trying to squeeze every ounce out of little chips !!
It is a timer interrupt clock cycle issue, one day I will fix it and hopefully keep it under 1k !!
Do you have any videos/youTube smaffer ?
smaffer
mcnobby
Very good smaffer !! :)
I dont have twitter, but I subscribed to your youTube :)
rob_cai
Dear Smaffer,
I want to thank you again in this post for your VGA library.
I have created a new post for the Arduino color game I have done using it, here it is the link.
You can find the code as well.
smaffer
mcnobby
I had a close look at your code today, just trying to see the difference between VGA and composite (PAL)
I believe the VGA line is 32us, whereas the composite line is 64us, so basically it is much harder to squeeze pixels into a VGA signal !
I have just written a new PAL driver for ATMega1284, its 352*280px, it reads BMPs off an SDcard and displays on the TV.. I still havent implemented that jitter fixer.. I havent got my head round it yet !!
I am using timer1 running flat out at 24MHz, I really wanted 32MHz but the '1284 couldnt handle it !! ha ha
Be really good to get the screen flicker free
ANYWAY.. your project looks awesome, I must try it when I get a chance !!
mcnobby
Hello Smaffer, if you are using a  CLS() in your library then perhaps consider THIS post.. I was asking for a way to clear a large array really fast, this was the video array in TVout
Some of the answers are quite interesting, in the end I decided to treat chunks of the array as uint64_t's and clearing them with one line
Also I considered writing an ASM routine that sits in the interrupt somewhere that will clear the display between writing frames to remove any flicker
I am now writing a simplified version of your code for an ATMega8
nickgammon
Cheers :)
I haven't looked at your code but I found jitter unless I put the processor to sleep (idle mode). It wakes up instantly and always on the same clock cycle so-to-speak.
nickgammon
Here, in particular:
  while(1) { // this is the main loop
    if (timer == 2) {
      // timed code here....
      shiftFwd(&H_GREEN_data[0]);
      shiftFwd(&H_BLUE_data[0]);
      timer=0;
You are waiting for the ISR to fire anyway, and when it does you will have a few clocks before you notice if timer == 2. So add a sleep:
    sleep_mode ();   // wake in a predictable way
    if (timer == 2) {
      timer=0;
In initialization, make sure sleep mode is idle:
  set_sleep_mode (SLEEP_MODE_IDLE);
smaffer
#12
Jul 26, 2015, 02:37 pm Last Edit: Jul 26, 2015, 02:42 pm by smaffer
Hi guys, i have created a small game for Arduino UNO, using my VGAX library. The game is called BIT NINJA and is a classic retro platform game like super mario bros. All the graphics and sounds are on flash (around 16k, for now). The gameplay is done using around 40 bytes of SRAM.
YouTube video:
LINK
Some of the code is taken from my program "maffiodo1" of the 23rd International Obfuscated C Code Contest (2014) (program screenshot1 screenshot2)
When the game will be finished i will publish the sourcecode online.
Happy hacking!
adgm1988
Has anybody tried using the VGAx Library on an Arduino Mega? what whould i consider? i tried using the same pins but couldnt make it work.
Thanks!
sspence65
I have the color bar sketch working from Nick Gammon's tutorial at http://www.gammon.com.au/forum/?id=11608
I notice smaffer's schematic dropped the blue connection (pin 3 on the vga connector) and it's associated 470 ohm resistor. Was that on purpose? and why?
Steve Spence - KK4HFJ
