Topic: Use value from a function in if else.. (Read 2711 times) previous topic - next topic
arduinofan90
Yes I understand I`m doing something wrong, thats why I asked the question.
But for me the way I see it, before I began with the if else thing and just had Front() Left() Right() in the loop it came out with how many cm it was from the sensors.
Now I think I have to return only cm and not the hole function. And rename cm to cmRight cmLeft cmFront... Just return that value because its only a number not any text. maybe that will do it.
luisilva
Try this:
Code: [Select]
#include <VarSpeedServo.h>
const int trigPinFront = 2;
const int echoPinFront = 3;
const int trigPinLeft = 4;
const int echoPinLeft = 5;
const int trigPinRight = 6;
const int echoPinRight = 7;
VarSpeedServo SteeringServo;
  SteeringServo.attach(8);
  long right, left, front;
  right = Right();
  left = Left();
  front = Front();
  if (right >10 && left > 10 && front > 10)         //SERVO MID POSITION WHEELS STRAIGHT FOREWARD AND START ENGINE FOREWARD
    SteeringServo.write(90, 25, false);
    // HERE I WOULD ALSO SET THE MOTOR TO GO FOREWARD
  else if (right < 10)                      //TURN Left
    SteeringServo.write(0, 25, false);
  else if (left < 10)                      //TURN RIGHT
    SteeringServo.write(180, 25, false);
  else if (left < 10 && right < 10)                      //SERVO MID POSITION WHEELS STRAIGHT FOREWARD AND START ENGINE REVERSE
    // HERE I WOULD ALSO SET THE MOTOR TO GO BACKWARDS
long microseconds2cm(long microseconds)
  return microseconds / 29 / 2;
long Front()
  long duration, cm;
  pinMode(trigPinFront, OUTPUT);
  digitalWrite(trigPinFront, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPinFront, HIGH);
  delayMicroseconds(10);
  pinMode(echoPinFront, INPUT);
  duration = pulseIn(echoPinFront, HIGH);
  cm = microseconds2cm(duration);
  Serial.print(cm);
  Serial.print(" cm foran");
  delay(2000);
  return cm;
long Left()
  long duration, cm;
  pinMode(trigPinLeft, OUTPUT);
  digitalWrite(trigPinLeft, LOW);
  digitalWrite(trigPinLeft, HIGH);
  pinMode(echoPinLeft, INPUT);
  duration = pulseIn(echoPinLeft, HIGH);
  Serial.print(cm);
  Serial.print(" cm Left");
  delay(2000);
  return cm;
long Right()
  long duration, cm;
  pinMode(trigPinRight, OUTPUT);
  digitalWrite(trigPinRight, LOW);
  digitalWrite(trigPinRight, HIGH);
  pinMode(echoPinRight, INPUT);
  duration = pulseIn(echoPinRight, HIGH);
  Serial.print(cm);
  Serial.print(" cm Right");
  delay(2000);
  return cm;
Delta_G
A whole function is never returned, only a value is returned from a function.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
Delta_G
Try this:
Code: [Select]
  right = Right();
  left = Left();
  front = Front();
long Front()
  long duration, cm;
  Serial.print(cm);
  delay(2000);
  return cm;
long Left()
  long duration, cm;
  Serial.print(cm);
  delay(2000);
  return cm;
long Right()
  long duration, cm;
  Serial.print(cm);
  delay(2000);
  return cm;
See how in this code the Front, Left, and Right functions return a value?  So now you can use them, and you don't have to do it this way with the intervening variables.  If the Front, Left, and Right functions are written this way you can write:
Code: [Select]
if(Front() > 10){ .. do something}
|| | ||| | || | ||  ~Woodstock
arduinofan90
Sweet! Thank you so much guys!
I know a function can only return one value not a whole function, I just didnt know how in this case.
You learn something new everyday;)
