Topic: Why does the order of this code change if an LED blinks or not? (Read 1 time) previous topic - next topic
SheCurvesMobius
Why is it that when I write my code this way in the "FOR LOOP A", pin 10 blinks during "FOR LOOP A":
Code: [Select]
int timer = 100;
  // Initialize each pin as an output
  for (int thisPin = 2; thisPin < 8; thisPin++) {
    pinMode(thisPin, OUTPUT);
  pinMode(10, OUTPUT);
  // "FOR LOOP A"
  // loop from the lowest pin to the highest:
    digitalWrite(thisPin, HIGH);
    delay(timer);
    digitalWrite(thisPin, LOW);
    digitalWrite(10, HIGH);
    delay(timer);
    digitalWrite(10, LOW);
  // "FOR LOOP B"
  // loop from the highest pin to the lowest:
  for (int thisPin = 7; thisPin >= 2; thisPin--) {
    delay(timer);
But if I write it this way in the "FOR LOOP A", it stays on for all of "FOR LOOP A" and then turns off right before "FOR LOOP B" starts? I can't understand the logic. I feel like it should blink durring "FOR LOOP A".
Code: [Select]
int timer = 100;
  // "FOR LOOP A"
    delay(timer);
  // "FOR LOOP B"
    delay(timer);
Thanks for your help!
dlloyd
In your second example, the output only appears to be always on, but it impulses low just for the time it takes to start the next iteration then write it high again. You'll need to delay after each transition so the high and low time remains equal.
Code: [Select]
int timer = 100;
  // "FOR LOOP A"
    delay(timer);
    delay(timer);
  // "FOR LOOP B"
    delay(timer);
    delay(timer);
SheCurvesMobius
Ah, of course!! Thank you so much. That helps me a great deal!
